Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-09-2009, 05:34 PM   #1
Insulation in back of the knee wall
In my cold space (back of my attic knee wall) I have 2X8 (71/4")floor joists. I am going to seal up behind the knee wall as I am finishing the attic space so it is air tight (except for the air channels that I have installed that carry into the cold space). Since I am having a hard time finding R25 in my area, I was planning to use R-13 faced on the bottom layer (Vapor facing down to my 1st floor) then adding another layer of R-13 unfaced on top of that within each bay then replacing the flooring. Or would it be better to use R-30 faced in each bay and don't put the flooring back so not to squeeze the insulation. I have seen the knee wall diagram on one of the websites, now just trying to figure out what size insulation I should use.
Vermont1 is offline   Reply With Quote
Old 03-09-2009, 06:03 PM   #2
Remodeling Contractor
more insulation is better if not squished as you noted. But R26 is okay in some areas and not in others. All depends on where you are at. The floor boards add some structure stability so they are to be considered in all of this.
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. Alright I want to show you this new wall right here. This new wall has all our sides we are... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We are going on to the next one as knee walls and we've got two different kinds of knee... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. R-Value is the ability of insulation. For instance, right here we are tempting to create two... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and an insulation inspection on this home. You want to think of knee walls being secured correctly. You can see this house with the... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
using plastic plus insulation to insulate an interior wall Taz38 Building & Construction 8 12-29-2008 08:44 AM
Removing knee wall and sistering rafters mn_homesteader Building & Construction 4 03-29-2008 11:38 AM
Knee wall door? luner99 Carpentry 5 04-09-2007 09:06 PM
Knee Wall Not Level cibula11 Building & Construction 14 03-10-2007 06:08 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
