Insulating Vaulted Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-27-2010, 12:30 AM   #1
Insulating vaulted ceiling
Have a vaulted ceiling, rafters are 12" engineered I beams. I can get 2" polyurethane foam boards at a good price. I was going to place the foam boards between the rafters leaving 1 1/4 " space between board and roof sheating, under the foam R35 fiberglass insulation, then vapour barrier then drywall.
Would this be a good way of insulating the ceiling?
Do I make the foam board layer air tight, or do I allow the insulation to breath?
My concern is the fiberglass between two non breathable layers....foam and vapour barrier.
Stephen
dodge1930 is offline   Reply With Quote
Old 09-27-2010, 07:31 AM   #2
Does this cathedral roof have continuous ventilation flow through the 1/4 inch gap? IE: soffit inlet and a vented ridge cap. Its sometimes recommemded to make the gap 2-3 inches. The 1/4 inch could be too restrictive. Is it asphalt shingles with tarpaper underlayment? Depending on your climate, you may want to omit the vapor retarder below for a more permeable air barrier instead.
rodeo is offline   Reply With Quote
Old 09-27-2010, 08:30 AM   #3
jlhaslip's Avatar
Rewards Points: 2,162
R35 might be too much batt insulation for that situation. The batt stuff needs room to fluff up.
Where are you located?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-27-2010, 09:46 AM   #4
I'm located in the eastern township of quebec, canada
the air space is 1 1/4 (one and a quarter).
The 2 " of polyurethane (not polystryrene) I understand gives me a R value of around R15 (The foam is foiled faced on both sides.
I was trying to acheive the upper R40's in the ceiling.
The roof has a continuous ridge vent with venting along the soffits.
The roof in covered with metal over 15/32 OSB.
I could drop the fiberglass down to an R30 9.5 inches.
Plus I will have strapping attached to the bottom of the I beam for the drywall, that could give me an extra 3/4 - 1 inch of space for the fiberglass.
Old 09-27-2010, 01:02 PM   #5
Registered User
Rewards Points: 5,516
You don't want air gaps at the batt insulation, behind or in front of to give convective loops. http://www.buildingscience.com/docum...archterm=insul
Especially in the channels created by the strapping.
http://www.buildingscience.com/docum...on?full_view=1
Need the v.b.: http://www.buildingscience.com/docum...rchterm=attic+
I would use foam or a sill sealer as a thermal break to the rafter bottoms from the heated room. http://www.coloradoenergy.org/procor...f/r-values.htm
Gary
Old 09-27-2010, 03:03 PM   #6
So if I as per my drawing. leave the 1 and 1/4 inch air gap above the foam board to vent.
install the foam board making it air tight.
install fiberglass
cover with vapour barrier
install strapping
install drywall onto strapping.
Foam board R -15
R30 fiberglass
total r = 45
Would this work?
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 06:51 PM
HELP! lighting question for vaulted ceiling pauls General DIY Discussions 5 07-03-2010 04:53 PM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 03:02 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
