Insulating Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-16-2007, 07:31 PM   #1
Insulating roof
Hi all, I'm stuck here in AZ, years ago the roof of the house I'm in right now was redone, but it was never cool coated. It's a flat roof, and I don't think there's any insulation to speak off, just empty space between the ceiling and the roof. What I'm wondering is, should I put some kind of insulation over the roof and then put a cooling coat on it, or is the cool coat enough? The ceiling is warmer than, say, the brick of the house, but it's not exactly hot. Thx all
rsilvergun is offline   Reply With Quote
Old 03-17-2007, 01:51 AM   #2
I'd say for sure put a reflective coating on it.There are alot to choose from with alot of differant advantages.
It's something you should really research alittle.I'd hate to see a guy spend good money on some box store crap when he could be using a far better suited product.
what kind of roof is it?still in good shape?what's your budget?
roofwiz74 is offline   Reply With Quote
Old 03-17-2007, 06:14 AM   #3
Commercial Roofing
AaronB's Avatar
Is the roof framing serving both as the roof framing and the ceiling framing, re is there a separation between?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-17-2007, 11:08 AM   #4
Hi all :)
Thanks for the replies :D. It hadn't occured to me that it could make that big a difference what I coated it with. I'll definately look into that. There is separation between the ceiling and the roof, about 8 inches through most of the house with 24 inches where the main hallway is (it's a small house, only about 1100 sq ft).
Old 03-17-2007, 10:09 PM   #5
Commercial Roofing
AaronB's Avatar
So, am I correct to conclude that the roof framing and ceiling framing are to separate structural components? MEaning that the roof joists do not also serve as the ceiling joists? If this is the case, you have a cold roof assembly and adding insulation on top of the roof will probably cost you more than it saves you....better to insulate to the top of the ceiling. I cool roof coating couldnt hurt, if it achieves Energy Star ratings of 70 aged reflectance AND is emmisive. This will aid in lessening radiant energy into the home converted from light energy from UV.
Old 03-17-2007, 10:24 PM   #6
cool, thx :)
I'll definately cool coat then. Should I consider some sort of insulation underneath the cool coat? I've seen sheets of foam or rubber that you nail down to the top of the roof and cover in paper and tar before insulating? Is it worth bothering with?
Old 03-17-2007, 10:26 PM   #7
sorry, misread your post ;)
You already answered my question, whoops .
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Insulating Aluminum roof rebrich1 Roofing/Siding 1 03-27-2007 07:54 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Insulating under part of my Flat Roof Hushpuppy Roofing/Siding 5 02-13-2006 03:45 PM
Flat Roof 3200sq ft insulating coleimage Roofing/Siding 11 01-18-2006 12:17 PM
