Insulating An A-Frame Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-28-2010, 09:54 AM   #1
Insulating an A-Frame Roof
I have a 2" tg pine roof, 4' c beams. I am considering using 2" or 3" hard styrophome insulation on inside and lay another tg pine paneling over this. Do I need to leave an airspace or can I put the insulation directly against existing tg pine current roof is 12x12 pitch, with 2" tg pine, 1/4 insulation and plywood then shingles
Or am I better off adding to the exterior, peeling off existing shingles, add 3" insulation followed by new roof?
jim8400 is offline   Reply With Quote
insulating sloped roof jr67z Building & Construction 3 10-14-2009 08:52 AM
Insulating roof rafters in Tenn ? weberus3 Building & Construction 2 10-01-2009 05:36 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Flat Roof 3200sq ft insulating coleimage Roofing/Siding 11 01-18-2006 11:17 AM
