Insulating Attic? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-01-2006, 10:34 PM   #1
Insulating Attic?
This might be off-topic, and if it is, I apologize.
I have a house that has zero insulation in the attic. I went up there and all there is up there is newspapers. Old newspapers spread around in the attic. there is paper between the joists that keep the papers above the joists, so if I blow in insulation it wont go between the joists.
My question is, can I just blow in the insulation right over the papers and the paper between the joists? Or do I have to remove all the paper so that the new insulation will go between the joists?
Another thing is if I do take it all out and put insulation between the joists and I want to remodel a room and want to take down the ceiling, then all of the insulation will fall down through the joists since there is no plastic holding it in.
I hope im making sense, but I dont know of another way to explain it. Look forward to hearing your replies.
Vikeologist is offline   Reply With Quote
Old 08-03-2006, 11:16 AM   #2
Commercial Roofing
AaronB's Avatar
Remove the newspapers and go with a 1.75# spray foam.
__________________ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
Insulating an attic for HVAC system BigJimmy Building & Construction 7 10-07-2006 09:10 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
