Installing A Tin Roof On A Storage Building? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-08-2014, 11:40 AM   #1
Installing a tin roof on a storage building?
I just tore down and moved a barn style storage building. It had a shingle roof with the felt and particle board underneath. I am going to put a tin roof on it when I rebuild it.
My question is, should I put the tin back down on the rafters or still use the particle board and a layer of felt paper?
Bob Loblaw Atty is offline   Reply With Quote
Old 08-08-2014, 11:44 AM   #2
Sorry didn't mean to double post.
Old 08-08-2014, 01:01 PM   #3
Rewards Points: 252
At minimum you would need to strap the rafters. Although without felt there's no safeguard against wind driven rain. i guess it depends what you will be storing.
Personally I would install new plywood and felt. It does not sound like it is a large building.
shazapple is offline   Reply With Quote
Old 08-08-2014, 02:19 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,036
Gotta have purlins and underlayment is recommended. If the rafters are open and you are going to heat the space, you need insulation as well.
Plywood is definitely recommended as well.
Old 08-08-2014, 02:32 PM   #5
Rewards Points: 13,446
Bet you have OSB not particle board.
Huge difference.
Particle board turns to oat meal the first time it gets wet.
Old 08-08-2014, 03:07 PM   #6
It is particle board, not OSB. That is what was used on it when I bought it.
The building is only a 10x12 barn style. Originally bought at Lowes I believe.
No plans to heat it. Just going to be used as storage. Furniture, mower, yard tools, etc...
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 10:06 PM
Building deck on side of Gambrel style roof - questions sheslostcontrol Building & Construction 14 05-10-2011 11:15 PM
Installing a rubber roof! Wildie Roofing/Siding 11 01-08-2009 07:14 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Installing New Roof PaoloM Roofing/Siding 1 08-12-2008 01:25 PM
