Installing Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-26-2010, 09:07 AM   #1
Installing Soffit
Hi,
I have been looking all over and have mainly seen new install of soffits is on wood framing houses. I need to install soffits and fascia on a concrete block garage that is separated from the house. At first, I thought the instructions were to install a F or J channel on the underside of the rafters at the top of the wall. After reading some more, I noticed that the soffit is level with the fascia. If I followed my initial thought of instructions the soffit would have a slight incline.
Is this correct or are there a few different ways of installing the soffit?
Thanks for your help,
johnc
johneecc is offline   Reply With Quote
Old 02-26-2010, 08:59 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
John,
The soffit should be level or perpendicular to the wall. If you have block walls to deal with, fasten a 2 x 2 belt to the walls with tapcons and then you have something to fasten your wide faced J channel to.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Need advise installing soffit vent scrupul0us Roofing/Siding 11 10-09-2010 07:57 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Installing new security light in soffit interplexr Electrical 2 12-27-2008 10:50 AM
Installing Soffit to Brick lima Building & Construction 2 08-24-2008 07:04 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
