Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-07-2009, 08:09 PM   #1
Installing a rubber roof!
In the spring I plan to build a roof over my concrete deck! It will be a 'shed style' roof attached to a ledger board just under the soffit of a 'hip' roof. The hip roof has a 9/12 pitch and this will meld into the new shed roof, which will have a 2/12 pitch. I'm considering using what i believe to be EPDM rubber roofing! My question is how to mate up to the shingled hip roof and how to finish it off, on the eaves!
Old 01-07-2009, 08:26 PM   #2
You will remove enough shingle courses to get the epdm up at least 3-4 feet. Then install shingles over the epdm staying up 10"-12" from the angle change.
On the remaining edges install drip edge over the epdm and strip with primer and 5" quick seam.
BornaRoofer is offline   Reply With Quote
Old 01-07-2009, 08:43 PM   #3
Thanks for the quick reply! I'm unfamiliar with the terms 'primer and quick seam', roofing isn't my strong suite! (that means that I don't know @#$%^ about it) LOL! if you would fill me in what these mean, I would appreciate it! The eave of the hip roof spans about 20 feet and the shed roof will span 14 feet. The new roof will be approximately centered. Thinking about running the EDPM up the hip, should I run it out beyond the shed roof, to the sides?
Old 01-07-2009, 09:07 PM   #4
Commercial Roofing
AaronB's Avatar
Dont use drip edge. Have a real perimeter metal fabricated.
Yes, you should go beyond the shed roof. You should also be aware that you will have to tie the roofing in to the shingle roof properly. This INCLUDES going beyond.
Am I correct to assume that you will have a fascia running into the shingle roof plane?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-07-2009, 09:20 PM   #5
Remodeling Specialist
The commercial flat roof drip edge with no lip, about 3"x3" works fine and it needs to be screwed down over the rubber which you will allow to hang over the edges about 2 inches. Use scissors when cutting.
What Bornaroofer was referring to is the metal drip edge then needs to be covered with a strip of rubber 5" wide and glued in place. If you cut strips by hand you can use rubber to rubber adhesive after cleaning both surfaces with the cleaner they sell for it, or use the prepared roll of seam tape (5" wide rubber in a roll) and buy the primer for it to glue it down over the drip edge top so the tape covers the drip edge but not over the sides.
All seams should get a bead of lap sealant to prevent UV deteriation.
They sell a video how to I am sure as I saw one when the materials first came out.
Baron is offline   Reply With Quote
Old 01-07-2009, 09:21 PM   #6
Tom Struble's Avatar
epdm is a great material and is perfect for the kind of low slope
application that your talking about.
But it has very precise installation procedures not really a diy project if you ask me.Epdm manufactures prefer factory trained installers
just my opinion
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 10:05 PM   #7
Yes, the fascia join to the existing house fascia!
Old 01-07-2009, 10:16 PM   #8
just my opinion
I just had the main building roof shingled a short time ago, and was impressed with the roofer that I hired for this! Whether he is capable of working with EPDM I'm unsure! I will be contacting him shortly! Although I have the building permit, I'm still working on the drawings for the roof and I want to be familiar with the roofing methods, before the plans are finalized! Thanks for your input!
Old 01-08-2009, 12:59 AM   #9
good you have a pro roofer doing the workIts just ive seen a roofing shingle crew really screw up a rubber roof good luck
Old 01-08-2009, 12:53 PM   #10
I guess that's why I posted here, so that I will be educated enough to choose a knowledgeable roofer!
Old 01-08-2009, 04:49 PM   #11
All of us Pros started as novices at one time.
Ask and learn.
Attempt the work and gain understanding.
Hire a pro and learn that all pros are not alike.
It is good that you ask questions now, rather then pay the price later.
Old 01-08-2009, 08:14 PM   #12
Ask and learn.
Thanks!
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Rubber Roof and Roof Deck vianak Roofing 2 10-09-2008 06:37 PM
Help with repairing a flat rubber garage roof Toasty Roofing 2 07-01-2008 09:43 AM
