Installing New Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 08:15 PM   #1
Rewards Points: 150
Installing new flashing
I had to replace some flashing on a roof because it was full of holes and rusted. The only problem was that one part of the flashing was behind the aluminum siding and I didn't quite know how to remove the siding so I could properly install the new flashing. How would you remove that first piece of aluminum siding? Is it similar to removing vinyl siding?
Steelhead is offline   Reply With Quote
Old 10-09-2009, 08:09 PM   #2
Commercial Roofing
AaronB's Avatar
No... if you want to reuse aluminum siding, you will have to cut the nails an slide it out pice by piece or you will ruin the siding.
If you dont mind re-doing the entire side, then just rip it!
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-22-2009, 08:05 PM   #3
Rewards Points: 150
thanks AaronB. So I would have to remove the siding from the top down by cutting the nails?
Old 10-22-2009, 09:31 PM   #4
Registered User
Rewards Points: 4,920
http://books.google.com/books?id=LPN...siding&f=false
Be safe, Gary
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 08:01 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Installing counter flashing Punjabtantrum Roofing/Siding 3 10-02-2008 08:06 AM
