#1 |
Installing ice-melting cable on old metal roof
So I have an issue with ice and snow sliding off my 95 year old roof into my neighbor's driveway. The only way I can solve this is to either install ice-melting cables or extend the height of his fence by 4 feet.
If I'm to go with the ice-melting cable route, what is the best way to install the clips to hold the cables into a metal roof without causing damage and leaks? Would a sheet-metal screw with a bonded rubber washer do the job? It's too cold to apply any sort of caulking and have it set properly. I'm not a fan of the idea of screwing into a roof that has gone this long without leaking. Extending the fence would likely be easier and cheaper. Any suggestions or ideas would be greatly appreciated. |
#2 |
Roofmaster
Melt wire is not for that purpose. Snow birds, and rails are. They make rails that attach to the ribs with set screws and have a tab that hangs down onto the pan to stop snow and ice from sliding.
" A lot of men build things, and a lot of things fall down " Last edited by jagans; 01-10-2013 at 09:49 PM. |
#3 |
There's dozens of differant things that can be added that keep the ice from sliding off until it breaks up and melts, here's just one of the many ways.
http://www.s-5.com/snow/index.cfm |
#4 | |
Installing ice-melting cable on old metal roofQuote:
My roof doesn't really have any ribs. It's a decorative patterned metal shingle sort of thing. |
#5 |
Roofmaster
Again, the purpose for melt wire is to melt tunnels through snow and ice to prevent ice damming, not to melt all the snow off your roof. That is why it is run in a continuous W pattern at the eaves.
Retaining the snow on the roof is not really a capital idea, so you should raise the fence. IMO
" A lot of men build things, and a lot of things fall down " |
#6 | |
Fencing it is! |
| Display Modes | |
| Leaking Metal Roof | debisans | Roofing/Siding | 1 | 10-23-2012 07:44 PM |
| Not venting a metal roof. | maestro | Building & Construction | 16 | 12-13-2011 03:31 AM |
| Voltage in Metal Roof and Gutters | TITAN2390 | Electrical | 4 | 10-07-2010 08:44 PM |
| condensation leak with metal roof on cathedral ceiling in Canada | Serialrenovator | Roofing/Siding | 10 | 02-02-2010 01:18 AM |
| Installing metal roof on Gambrel Barn | Ron Hill | Roofing/Siding | 3 | 02-01-2009 11:31 PM |
