Installing Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-28-2007, 10:28 PM   #1
Rewards Points: 47
Installing Gutters
I replaced my gutters. Unfortunately the gutters are slated downward (from the front) too much. Is there a way to adjust the gutter upwards easily?
Any help would be greatly appreciated.
tate16t is offline   Reply With Quote
Old 09-29-2007, 07:41 AM   #2
Rewards Points: 47
The slope I'm referring to is from the front. The slope which allows the rain to run downward is fine.
One relevant point I failed to mention is the facia the gutter is attached to is slated.
Old 09-29-2007, 04:41 PM   #3
Do you mean "slated" or slanted?
Are these hung off the roof or screwed to the fascia?
redline is offline   Reply With Quote
Old 09-29-2007, 05:18 PM   #4
For a slanted fascia, there should be wedges, (Little tiangular shaped supports for the back side of the gutter), applied behind and attached to either the gutter or the slanted fascia board to keep the gutters in a truer horizontal plane.
If you are speaking about a steep roof with crown mouldings on, then the gutter hangers brackets should be attached to a T-Lock gutter hanging strap, which get nailed onto the sloped roof under the bottom row of shingles. If that is the case, then the heightr of the hangers is not correct.
Ed
Ed the Roofer is offline   Reply With Quote
leaf free gutters icicles and ice dams bluemetro Roofing/Siding 16 02-23-2010 09:14 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Gutters Malcolm Roofing/Siding 6 08-01-2007 09:20 PM
Valleys' water over-flowing gutters davco Roofing/Siding 2 06-11-2007 08:15 AM
