Installing A Gutter On An EPDM Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Poll: Have you ever experienced ice back-up with EPDM's "Gutter Trim"?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Poll Options
Old 04-24-2011, 03:02 AM   #16
WoW, I really like the tapered insulation board idea - thanks! I suppose the term-bar in addition to the edge metal may be considered over-kill, but if the EPDM wraps down and around the fascia enough it will be below the gutter and not behind it. . ... hmmmm, maybe my fascia board is not wide enough for the term bar to end up below the gutter ... I'll have to go take another look. Thanks for your ideas. I will take all into consderation. This is a very helpful forum!
Linda135 is offline   Reply With Quote
Old 04-25-2011, 12:10 PM   #17
Low Slope Roofing
Rewards Points: 114
The EPDM shouldnt go past the bottom of the gutter, (eye sore). I forgot a response to your Box gutter/ Drip egde. We shop form all of ours. Any flat roofer should have a sheet metal brake to do this. I could make some and send them to you but I have a feeling you wouldnt like the shipping costs on a 10' item. To get an idea of he gutter were talking about it would be the "boxed gutter flanged" http://www.rutlandguttersupply.com/g...utters_Box.asp
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Linda135 (04-25-2011)
Old 04-25-2011, 05:49 PM   #18
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Same gutter I posted earlier in the thread.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
The Following User Says Thank You to Grumpy For This Useful Post:
Old 04-25-2011, 08:53 PM   #19
Gutter info
Thank you both very much for the information and links for the gutter. I am definately going to try to get some, if at all sold locally or if I can find some one to fabricate it. Indeed, shipping would be too much. I wish you all lived closer .. I would hire you in a heartbeat. You sound like you really know your stuff. I hope I can find someone who understands flat roofs like you do. Thank you again! Linda
Old 04-25-2011, 09:23 PM   #20
The EPDM gutter detail is baby shoes I mean if the roofer is going to install a fully adhered tappered roof system. And then he needs to be instructed on how to do a gutter. Really ???. If he gets that far with out screwing it up I think he's good to go...... Just saying
Don Smith is offline   Reply With Quote
The Following User Says Thank You to Don Smith For This Useful Post:
Old 04-25-2011, 10:27 PM   #21
You make a valid point, however, I've interviewd a half-dozen contractors and NONE of them considered a tapered iso board, and NONE of them suggested the self-flashing gutter, and only half of them were willing to install the EPDM down the fascia (the other half insisted the 'right' way to do it was to install the epdm up to the edge of the roof and install a metal drip edge there). I've seen where that way is acceptable, but then read where the wind lifted it up, and it was better to have the edpm go down over the fascia. Some guys just did not want to do it the other way. One roofer said that if I didn't want the ice in the gutter to freeze and get under the epdm, then don't install the gutter .... not the solution I was looking for. I hope I hire someone who 'gets it" as well as you!
Any recommendations iin the Connecticut area? Tough since it is only 26 x 22, but I am also re-roofing the shingled area, and building a 10x12 pt deck in the back.
Thx, Linda
Old 04-25-2011, 11:00 PM   #22
[quote Your doing the right thing ask alot of questions to the contractor. Do your home work. Good luck to you
Old 04-26-2011, 07:21 AM   #23
Grumpy's Avatar
Rewards Points: 552
That's the problem. You've interviewed contractors, not roofers. Or maybe shingle roofers, not flat roofers. Or maybe salesmen for roofing companies that don't understand the products they are selling.
Point being WE do not make these things up as we go along. If we did we wouldn't all be saying the same thing. A professional roofers has likely read a spec book or looked at a detailed drawing or worked under the tutilage of someone who has.
Have you tried contacting the National Roofing Contractor's Association www.nrca.net or the National Roof group www.rooferdata.com ? A member of the NRCA will likely understand basic details such as a gutter because when they join they get the roofing manual free of charge.
Is a license required in your area to be a roofer? If so don't even think of hiring someone with out it. You may also check into the certifications of the roofing contractor. I truly feel that a professional roofing contractor will have at least some certifications. Certifications don't make you professional, but they don't hurt either.
Old 04-29-2011, 04:37 AM   #24
Yes, I will have the torch-down roofing removed down to the plywood, install 1" ISO board, EPDM roofing installed under the shingles (which is also getting torn off to the plywood and re-roofed) and the EPDM will go down all 3 sides' fascias. I think I'm starting to 'get' this. Thank you .. .. thank you all!
kimboy is offline   Reply With Quote
Old 05-04-2011, 02:39 PM   #25
Hi, how would one pitch the self-flashing gutter? I ask here because I know i will get the best answers here. Thanks. Linda
Old 05-04-2011, 10:54 PM   #26
Low Slope Roofing
Rewards Points: 114
Well you can and you cant. If you buy the ones like say online you really cant. If you have someone make them, and they are good sheet metal people they can build the slope in to the profile. Also it depends how long the gutter is. Say 20' I wouldnt bother making a sloped gutter. 40-50' Yes of course. You could do a regular K style and do a normal drip edge. If the EPDM is behind the gutter ont he fasica and back side of the gutter covers the EPDM you wont have to worry about Ice damns.
Old 05-11-2011, 09:54 PM   #27
Call me Stupid??...
install gutter with a few nails to the facia just to hold in place. Caulk the back of the gutter, and then term bar the epdm into the caulk, with screws and hidder hangers????
Kj4x10n is offline   Reply With Quote
Old 05-23-2011, 05:12 PM   #28
Grumpy's Avatar
Rewards Points: 552
Linda if you look at my website Commercial Box Gutters you will see the back of the gutter is higher on one side than the other. Well maybe it's not incredibly obvious because the gutters shown are short but, the pitch is bent into the gutter when the gutter is fabricated. This is truly a custom gutter for each building, our fabrication shop will typically build 2-3" of pitch into a average 24' gutter.
1985 is right you can use a regular gutter, but it's much more difficult to use the shingle roof gutter (k style) on a flat roof. First the rofo membrane would wrap the fascia, then the gutter would be installed, then a strip of membrane sealed to the roof and wrapped into the gutter, then a termination bar in the gutter. It'll work, but alot of extra work.
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Installing plywood or chipboard over 1X6 planking on a 52 year old house' roof. JBfromSD Roofing/Siding 2 09-20-2010 10:09 PM
Patio Flat Rubber Roof installed, and gutter cleaning - ripped off? mark2741 Roofing/Siding 17 03-08-2010 11:55 AM
Small EPDM Roof for Addition stubits Roofing/Siding 5 03-20-2009 05:48 AM
Installing a rubber roof! Wildie Roofing/Siding 11 01-08-2009 07:14 PM
