Installing Counter Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-01-2008, 06:36 PM   #1
Installing counter flashing
I was told that I needed to install counter flashing over my existing step flashing on the rear of my home. Can anyone guide me in the right direction to do this myself? I have attached a pic where this is to be done. Looks like it was there before and held on with some sort of caulk.
Punjabtantrum is offline   Reply With Quote
Old 10-01-2008, 07:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Counter flashing (lead), must be installed (cut into and inserted, then sealed) into the brick work. I'd suggest that you hire this out, it is not the typical beginner DIY project.
- Build Well -
Old 10-01-2008, 09:18 PM   #3
For the step version and mortar embeddment version you will need a grinder and a diamond blade. I use a 1/4" wide blade to allow plenty of room so I don't have to re-cut the raggle joint.
Then you need a sheet metal brake and have to bent either one continuous piece or individual step counter-flashings and implant them into the reglet that you cut out of the masonry wall.
You can eithe ruse Tap-Cons or lead masonry nail-ins to secure the counter-flashingss to the joint and to the wall.
Foam backer rod and a good back sealant should be used in the joint if you are not re-mortsring it.
A surface mounted version can also be donew, but if done incorrectly, is more prone to leakage.
Either way, the roof cement needs to be completely cleaned off of that wall first.
Ed
Ed the Roofer is offline   Reply With Quote
Old 10-02-2008, 08:06 AM   #4
Residential Roofer
Slyfox's Avatar
Tools:
<> Good hammer, 18 ounce or heavier.
<> Flat bar, wide wood chisel or flat head screw driver.
<> A rag, to throw a way afterwards.
<> One tube of caulking for every 10' foot of wall.
<> A piece of alluminum coil, how ever many feet long as the wall.
"if you have two walls 10' long, than one piece of metal 10' long will do both, because you don't need a full width of the metal coil"
<> Handfull of masonery nails, 1 1/4" in size.
Higher a handyman, roofer, sider or metal guy. Or follow these steps.
<> Scrape all existing roof cement/tar off the brick, take care to not damage or bend existing step flashings.
<> Run a light bead of caulking across the top of the step flashings,
half on the flashing, half on the wall,
and smooth it in with above mentioned rag.
<> Cut your metal to the lenght you need,
than cut it to 6 inches in height, less if you need to in order to avoid hitting the window but no less than 4", using your hands, carefully, CAREFULLY put a slight bend at the top of the counter flashing, make sure that bend faces the wall when you install the metal.
<> Place the 'pre-cut' metal against the wall with it starting roughly one inch below the start of the step flashings and ending at the ridge above,
the bottom of the metal should be roughly 1" above the break where the roofing and metal meet,
starting at the bottom end place one fastener into the nearest morder joint and firmly pound the fastener in, and continue placing fasteners no less than every 3 feet all the way up the wall to the end,
than caulk all along the top of the counter flashing, half on wall, half on flashing and smooth in with the rag.
Assuming all fasteners went in ok, your done.
If a fastener bends or breaks the morder, you can repait that with simply caulking the hole really well, but take care not to have many bad fasteners.
Never try and install a fastener any closer than 2" of any corner or extrusion.
Hope I didn't miss anything.
Good Luck.
Edited to add,
you can purchase above mentioned materials and tools at most hardware stores,
especially chains such as Lowes and Home Depot, etc.
But if you go to a local roof supply store and tell the sales rep what your up to,
they can put together a package of what you need, including pre-cutting and bending the metal for efficiency and safety.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Tags
counter flashing , flashing , roofing , step flashing
Counter flashing where roof meets vertical brick wall sandyman720 Roofing/Siding 5 02-20-2011 11:13 AM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
Installing a Granite counter top DaleB General DIY Discussions 2 03-13-2008 08:10 AM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 09:30 PM
installing granite counter tops dnassif Remodeling 4 07-01-2006 09:37 AM
