Installing Asphalt Shingles Without Nailing Clearance? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2013, 09:47 PM   #1
Installing asphalt shingles without nailing clearance?
We are adding a small room to the side of our home. There isn't enough room between the new roof and existing soffit to nail shingles. What can I do to fasten these shingles down securely?
I'm looking at using architectural asphalt shingles that match our current roof. There is about two feet of the roof where we won't be able to nail.
I would consider gluing them down, but with tar paper underneath, I'll only be gluing them to the paper and not the sheathing.
What can we do?
Calab is offline   Reply With Quote
Old 06-29-2013, 10:01 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,316
Go ahead and nail in the exposure... put a dolop of caulk on top the nail
MTN REMODEL LLC is offline   Reply With Quote
Old 06-29-2013, 11:54 PM   #3
Doing This Way Too Long
Rewards Points: 532
palm nailer?
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
kwikfishron (06-30-2013)
Old 06-30-2013, 09:26 AM   #4
Rewards Points: 652
If its going under a 2' overhang on the side, cut the overhang in half. You will have to get flashings in there anyway.
PatChap is offline   Reply With Quote
Ridge Vent vs Attic Fan?? Different info from pro roofers MrsJoseph Roofing/Siding 31 03-08-2013 05:27 PM
Asphalt shingles Rilley Roofing/Siding 6 04-20-2012 10:07 AM
Installing metal flashing shingles stymie222 Roofing/Siding 1 07-13-2011 04:33 AM
Energy Star Qualified Asphalt roofing shingles? Scuba_Dave Roofing/Siding 50 09-28-2010 02:25 PM
installing replacement cedar shingles gcorliss Building & Construction 1 06-01-2009 09:54 PM
