Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-18-2010, 11:51 PM   #1
installation of natural passive vents
I just realized that I might have made an error on the installation of passive vents on my roof. I used 4 round passive vents with 144nfa for an attic that has 2500 square feet. I followed the calculations of the OC web site; soffit nfa appropriately corresponds to the 4 passive vents. However, I did not alter the openings of the old vents; they are 8" X 9" rectangles. I just noticed the instructions for the new passive vents state that there should be a 14" diameter in the cut out in the roof. That comes to 153 square inches compare to my 72 square inches.
should I do anything"? right now at 11:43 PM it is close to 100% humidity outside the house (weather report says 100% but it isn't raining) and according to my humidity reader in the attic it is only 44% (I closed the staircase, left the reader in the attic for several hours and just returned to read it; the reader gives me approximately the same readings as a downstairs dehumidifier that I have so I expect it is quite accurate). I will monitor over the next day. The last time I checked the temperature it was 89 degrees outside and 85 in the arttic. right now it is just a little cooler in the attic than outsider. Seems to be pretty moderate in all of this, so shoudl i do anything to correct the situation.
My roof is all in (except for some trim pieces on the ridge; I ran out). No leaks; looks professional and beautiful. But , if I do have to correct the opening can i cut it larger from insider the attic. What should I do at this point?
Alto is offline   Reply With Quote
ridge vents vs. box vents vs. turbine vents redaws Roofing 12 03-12-2012 10:48 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing 9 07-22-2010 07:20 PM
Ridge vents and roof vents jerry1967 Roofing 4 06-07-2010 06:40 PM
New Natural gas installation, many questions f4urak Plumbing 1 10-14-2009 12:13 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
