Install Felt Over Ice & Water Shield - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-20-2012, 10:52 AM   #1
Install Felt over Ice & Water Shield
It is my understanding that Felt Paper should be installed over Ice & Water Shield. Isn't this correct?
MarkStrutko is offline   Reply With Quote
Old 06-20-2012, 12:26 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Not required. Best to do it though because the I&W will weld itself to the shingles and removal later will nearly be impossible.
Last two roofs I tore off that had I&W had to be redecked anyway since I couldn't get a smooth working surface.
tinner666 is offline   Reply With Quote
Old 06-20-2012, 08:28 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
Tinner is dead on accurate.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Ice and water shield SamReynolds Roofing/Siding 13 08-31-2010 02:03 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
