-   Roofing (http://www.diychatroom.com/f9/)
-   -   iko quick cap adhesive roof (http://www.diychatroom.com/f9/iko-quick-cap-adhesive-roof-127452/)
gkaro 12-23-2011 02:00 AM
All.
Building an extension with a flat roof. I came across iko adhesive rubber type roof.
What luck would I have with this at freezing point temps.
Also is the torch type superior...?thanks
Slyfox 12-24-2011 06:34 AM
You can read about the IKO low slop material >click here<, it's designed for low slope application, not flat, so make sure your addition is at least a 1/12 pitch.
I would rate it as a fair product.
gkaro 12-24-2011 07:28 AM
Thanks. The plans call for a 1 to 50 slope.
shazapple 12-25-2011 08:53 PM
The torch type would be superior (not a DIY job), especially since that would typically require a base sheet (aka you'd have two layers). They do get installed in cold weather, but it is not recommended and you don't get a quality job. The instructions recommend +10 degrees centigrade, so with temps below that the adhesive wouldn't work well.
gkaro 12-26-2011 10:49 AM
Thanks. What kind of base layer would go under a torch rubber roof?
Slyfox 12-27-2011 07:31 AM
The self adhered systems come with base & cap sheets also and are far less dangerous being there's no open flame to contend with.
tinner666 12-27-2011 10:13 AM
In low temps, you can use a Wagner heat gun, for paint removal, to warm the material and other surfaces. It could possibly, with practice, be used to weld the seams and joints too.
tinner666 12-27-2011 10:14 AM
I would recomend the nailable base, 2 inter-ply sheets, then the cap sheet. Read the instructions so the seams are all staggered and not on top of each other building ridges in the roof!
