Ideas On Airlift Water Pump - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-19-2012, 10:18 AM   #1
Ideas on airlift water pump
We had our water pump go out in our well, after pulling it out and finding that the pump was out my wife started a search for a new pump.
Recently she came across youtube and videos of what is called airlift water pumps, using no electricity or such, but just plain air forcing the water up.
It sounds good, but I have a question or two concerning this. First off the videos show it being used pulling water directly from the well using a small air compressor, we have a pitless connector that goes into the house, and in the basement we have a water tank.
What I want to know from anyone who has done this with a airlift water pump, can it be possible to use this method to get water in the house using the airlift and the water tank.
The water tank in the house helps pull water from the line when the pressure drops below 25psi and fills up. Can these two work in conjunction thus avoiding paying some 600 bucks or more to get new pump and wiring
thetimelord4 is offline   Reply With Quote
Old 04-19-2012, 10:21 AM   #2
Civil Engineer
Rewards Points: 4,518
Where do you plan to get the power from to run the compressor? If you use electricity, then you incur the cost for the compressor, the electricity, and the wiring. If you use a gasoline or diesel powered generator, you incur the cost for the generator, the wiring, and the fuel. I don't see a free lunch here.
Old 04-19-2012, 01:46 PM   #3
Rewards Points: 12,828
I just see no up side to trying to do it that way.
If it worked everyone would be doing it.
Go back and see some more reseach, pay attantion to how much head one of those style pumps can pull. I'd bet it's pretty low.
I think you will find it works on a the same princable as blowing across the top of a straw and drawing water out of a glass.
http://www.merriam-webster.com/dictionary/venturi
Old 04-21-2012, 03:39 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
Nope....
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
What is this HVAC Heat Pump System - Water Pipes To Indoor Coil? kentkeith HVAC 20 01-17-2011 05:07 AM
