Icicles On Soffit Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-07-2008, 08:51 AM   #1
icicles on soffit vent
I noticed these icicles coming out of one of my soffit vents today. We had a snowstorm yesterday. It is the only vent that has them. I know that my attic has at least enough ventilation to meet the warranty requirements of Certainteed shingles, because I was instructed to increase the soffit ventilation, and add ridge ventilation, when I put on a second coat of shingles about ten years ago. I have no watermarks on my celing.
I also added a vinyl covered aluminum to my fascia boards last summer, to make them easier to maintain.
I had a direct venting furnace installed last year, the exhast tube is below this vent, and I did notice that the moist exhaust is rising up to directly where the condensation is occuring.
I have never seen this happen before. Any ideas? Anything to be concerned about?
Thanks,
Brian
Last edited by brianbh; 02-07-2008 at 11:23 AM. Reason: Found out furnace exhast goes up there
brianbh is offline   Reply With Quote
Old 02-07-2008, 09:43 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could have Ice dams, or ice backing up and melting into your interior soffit/ eaves, and possibly your lower attic. Get up in your attic and check it out with a good flash light.
Check the insulation in your attic for proper thickness and no escaping heat. Also, check your baffles/rafter vents, your soffit vents (in your pic) as well as the function of any other the ventilation up there.
Link Info: http://www.extension.umn.edu/distrib...ng/DK1068.html
Based on your exterior picture, this is what the interior could look like:
- Build Well -
Old 02-07-2008, 10:49 AM   #3
Also, since the icicles seem to be only at the one soffit vent area, I would check inside the attic for any bathroom exhaust fans not properly ducted to the exterior of the roof. The flexible tubing my not be adequately secured to the damper vent on the roof or to the ceiling fan in the bathroom.
This could account for the localized excessive trapped vapor turning into icicles.
Also, just above and around the area, I would buy a "Snow Rake" which costs about $ 30.00 at Home Depot, and from the ground, pull the snow off of the roof surface completely around the area above the soffit vent giving you the problems from the recent snow fall. It may just be an isolated ice dam area and you can eliminate the source of the dam that way.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-07-2008, 11:02 AM   #4
I went into the attic to look around. Everything looks dry around that soffit vent. The bottoms of the can vent covers had some condensation on them. The screen below the covers is dry, and the roof sheathing around them, along with the ceiling insulation below it, is all dry.
I don't have any gutters around that part of the home, so ice damming is near impossible.
Old 02-07-2008, 11:51 AM   #5
gutters have nothing todo with ice damming. ice damming is when heat from home warms roof surface causing snow to melt, when snow gets to unheated overhang it freezes and starts to build up , snow continues to melt up higher and then seeks nearest opening (shingles have seams every 3') if you did a roof over , chances are you don't have ice and water shield on your eves.
big daddy-o is offline   Reply With Quote
Old 02-07-2008, 04:02 PM   #6
I was not referring to the regular attic exhaust vents, (mushroom or turtle style vents), but to one that should be hooked up to a ceiling fan with a flexible duct tubing connecting to a damper vent on the roof.
This is one common brand and style of the damper vent, manufactured by Broan. Under this vent in the attic, there is usually a white thin flexible plastic duct tubing with a coiled spring inside of it for support so it does not collapse upon itself.
If the ceiling fan in the bathroom, (or kitchen range hood), does not have this tubed ducting connected to it, then all of the internal humidity from the bathroom gets exhausted directly into the attic area and will create excessive moisture-mold-condensation in the nearby areas.
Also, by any chance, do you have a clothes dryer vent on the wall directly under this icicle laden soffit intake vent?
If so, then the intake vent is pulling the exhaused air from the dryer vent on the wall into the attic at that location and could also be the source of this isolated problem.
Ed
Old 02-09-2008, 08:12 PM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
while not a cause of ice damming gutters do contribute to it and commonly create the situation where the ice backs under the shingle edge at the fascia and enters trhe soffit area,and then runs down your bearing wall of the house,big daddy-o describes an ice dam but neglects that the melted ice travels to the bottom and freezes on the unheated area of the roof ,typically the soffit,and where there is no soffit, at the gutter.the gutter backup situation is by far the most prevalent,and what is evident in your photo,the recommendation for ice+water shield is valid and should be installed up to 2 ft. past the bearing wall,but should also have flashing to close the gap between the fascia,and the roof sheathing,which would also extend down past the back of the gutter for proper protection,this works well;
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Soffit Vent Sizing - Really Hot Attic dmo069 Roofing/Siding 7 12-04-2008 10:33 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
