Ice/water Underlayment - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-01-2006, 08:03 PM   #1
Question
Ice/water underlayment
Is it necessary to install ice/water underlayment on the eaves of an un-heated garage that is attached to the house?
twaters12 is offline   Reply With Quote
Old 03-01-2006, 08:17 PM   #2
MJW
In MN the inspectors want it on everything, even if it's a shed. I'm pretty sure it is code. Whether it is heated or not, it can still have ice on the eaves.
MJW is offline   Reply With Quote
Old 03-01-2006, 08:26 PM   #3
Smile
Thanks! I'm in upstate NY. Our local codes says one thing and the State code says another. We do get some ice here.
Old 03-01-2006, 09:49 PM   #4
Commercial Roofing
AaronB's Avatar
You will still get some ice with snow melt from daytime sun and nighttime freeze, but not like youll get from indoor heat escaping to the attic and enhancing the thaw and re-freeze overthe eave, even during the day on the really cold days. I have no heat ion my garage, and do not get ice dams, even with the biggtest snowfalls.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-03-2006, 07:22 AM   #5
I think it is a good idea, due to the sunmelt ice dams mentioned. I believe code requirements are 24" inside the warm wall, which implys heated space only. In my area, ice dam protection is not required for unheated areas.
Jim
jmorgan is offline   Reply With Quote
Old 03-04-2006, 07:33 PM   #6
Smile
Thank you all for your help. It is appreciated.
Old 03-04-2006, 09:04 PM   #7
747
registered
747's Avatar
Rewards Points: 534
I don't either and i have a two car detached garage not heated and not insulated.
Ps. Ice and water shield isn't a code requirement where i live. Because when my house was re roofed last summer i said i wanted it and the carpenter said i really didn't need it but he could put it under the starter singles above gutters.
747 is offline   Reply With Quote
Old 03-05-2006, 08:43 PM   #8
I'm not sure where kankakee county is, but the greater Chicago Area requires ice dam protection as per code. 24" inside the warm wall. Grumpy is from IL., maybe he will see this and respond. Or try posting to www.rooferscentral.com, he will see it there for sure.
Jim
Old 03-05-2006, 11:35 PM   #9
Commercial Roofing
AaronB's Avatar
Im in Illinois also, and Chicago doesnt even require a permit for roofing. No Inspectiona are ever doen, no code is ever enforced regarding roofing.
Some municipailties require it for heated space, some do not.
Old 03-06-2006, 02:04 AM   #10
747
registered
747's Avatar
Rewards Points: 534
Aaron did you have to get one for your sisters house. If so what was city hall in momence like to deal with for a permit? Just curious.
Old 03-06-2006, 09:31 AM   #11
Commercial Roofing
AaronB's Avatar
My sister got the permit, so I really dont know exactly how they are, but she said Mommence was really willing to work with them to make sure everything was up to code. They did come and inspect the framing and structure.
Old 03-15-2006, 07:52 PM   #12
Ice / water Shield
Twaters12
N.Y.S. Residential Code requires ice and water shield 24" from outside wall--but it"s a good idea to do your garage, some time you might want to insulate the garage.
al
THEMAN is offline   Reply With Quote
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
health concern of asphalt felt paper for hardwood underlayment rrbb Flooring 2 09-04-2006 09:10 AM
Underlayment for laminate dm62 Flooring 3 04-02-2005 10:56 AM
