Ice & Water Shield On Saltbox Colonial? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-03-2011, 10:27 AM   #1
Ice & water shield on saltbox colonial?
I am having roof redone and had ice dams last winter. I have a saltbox colonial; and the knee wall extends about 7' up. (on the angle) should I have the Ice & water shield go higher than 6' in the back of the house where I have the knee wall? Hard to find a consensus for this question.
Currently the roof side of the knee wall is insulated rather than the living area side. It has been suggested I insulate the living area side and leave the roofing side in place. This side of roof has a fairly steep pitch.
BruceA is offline   Reply With Quote
Old 10-03-2011, 10:48 AM   #2
Framing Contractor
Rewards Points: 118
It depends. It sure wouldn't hurt though. Especially important on lower sloped roofs. Ventilation is probably the cause of your ice dam though.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
BruceA (10-03-2011)
Old 10-03-2011, 11:35 AM   #3
MJW
Ventilation and lack of room for insulation on the knee wall is the problem. Have that addressed correctly and the house will perform better inside and out.
More I&W without doing more insulation and better ventilation will just make keep more moisture, condensation, and ice in the house and/or on the underside of the I&W. Then it will melt and rot the roof boards. Fix it right and be done with it the first time.
MJW is offline   Reply With Quote
The Following User Says Thank You to MJW For This Useful Post:
BruceA (10-03-2011)
Old 10-03-2011, 03:26 PM   #4
Residential Roofer
Slyfox's Avatar
You should have the i&w go higher then 7', then like MJW posted, look into other issues going on and see what you can do to correct them.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
BruceA (10-03-2011)
Old 10-05-2011, 12:01 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,116
+1
Well said.
Old 10-29-2011, 02:03 PM   #6
insulation?
In addition to adding more venting would you recommend I insulate the living area side and leave the roofing side in place?
Old 10-29-2011, 03:02 PM   #7
Rewards Points: 2,238
Post some pictures.
It could help.
rossfingal
rossfingal is online now   Reply With Quote
Old 10-31-2011, 08:37 PM   #8
picture of eave
This is a picture of the eaves
Old 10-31-2011, 08:47 PM   #9
In these scenarios, there is no way that they insulation layer that is represented by a roughly 3" batt of fiberglass is anywhere near adequate.
I would put air tight foam on the living side and up the insulation value. Get it air tight as well.
The Following User Says Thank You to Windows on Wash For This Useful Post:
BruceA (10-31-2011)
Old 10-31-2011, 09:31 PM   #10
re foam
Thank you for your reply. I had never heard of doing foam insulation, I suspect is not that popular here in MA. It sounds somewhat complicated & expensive. I have seen fiberglass batts then a cover to seal that looks like foil covered bubble wrap.
Old 10-31-2011, 10:35 PM   #11
Spray foam is going to be more expensive than its fiberglass counterparts.
You can use rigid foam and get the same R-Value benefits as compared to fiberglass.
Fiberglass as an insulator is pretty abysmal in most cases.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Ice & Water Shield?? blackout Roofing/Siding 5 09-17-2009 07:54 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
