-   -   Ice & water shield on saltbox colonial? (http://www.diychatroom.com/f9/ice-water-shield-saltbox-colonial-119111/)
BruceA 10-03-2011 10:27 AM
I am having roof redone and had ice dams last winter. I have a saltbox colonial; and the knee wall extends about 7' up. (on the angle) should I have the Ice & water shield go higher than 6' in the back of the house where I have the knee wall? Hard to find a consensus for this question.
Currently the roof side of the knee wall is insulated rather than the living area side. It has been suggested I insulate the living area side and leave the roofing side in place. This side of roof has a fairly steep pitch.
sixeightten 10-03-2011 10:48 AM
It depends. It sure wouldn't hurt though. Especially important on lower sloped roofs. Ventilation is probably the cause of your ice dam though.
MJW 10-03-2011 11:35 AM
Ventilation and lack of room for insulation on the knee wall is the problem. Have that addressed correctly and the house will perform better inside and out.
More I&W without doing more insulation and better ventilation will just make keep more moisture, condensation, and ice in the house and/or on the underside of the I&W. Then it will melt and rot the roof boards. Fix it right and be done with it the first time.
Slyfox 10-03-2011 03:26 PM
You should have the i&w go higher then 7', then like MJW posted, look into other issues going on and see what you can do to correct them.
Windows on Wash 10-05-2011 12:01 PM
+1
Well said.
BruceA 10-29-2011 02:03 PM
insulation?
In addition to adding more venting would you recommend I insulate the living area side and leave the roofing side in place?
rossfingal 10-29-2011 03:02 PM
Post some pictures.
It could help.
rossfingal
BruceA 10-31-2011 08:37 PM
picture of eave
1 Attachment(s)
This is a picture of the eaves
Windows on Wash 10-31-2011 08:47 PM
In these scenarios, there is no way that they insulation layer that is represented by a roughly 3" batt of fiberglass is anywhere near adequate.
I would put air tight foam on the living side and up the insulation value. Get it air tight as well.
BruceA 10-31-2011 09:31 PM
re foam
Thank you for your reply. I had never heard of doing foam insulation, I suspect is not that popular here in MA. It sounds somewhat complicated & expensive. I have seen fiberglass batts then a cover to seal that looks like foil covered bubble wrap.
Windows on Wash 10-31-2011 10:35 PM
Spray foam is going to be more expensive than its fiberglass counterparts.
You can use rigid foam and get the same R-Value benefits as compared to fiberglass.
Fiberglass as an insulator is pretty abysmal in most cases.
