Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-15-2009, 08:19 PM   #1
Question
Ice & Water Shield??
We are currently getting quotes for the roof to be stripped & re-shingled on our 30 year old side split.
Out of all the quotes we've gotten we've narrowed it down to one guy, but we're not sure about his theory on ice & water shield.
He says there is currently a shield of some sort in place under the existing shingles, and he can feel it. He says it's not necessary to put a new one down if there's one there which makes sense. However a different roofer said that it might be some outdated product and if it isn't ice & water shield that it should be replaced.
The guy we want to go with says that ice & water shield is overkill anyway and that if tar paper is used properly it serves the same function.
He has said if we want the ice & water shield he will install it for us, but he doesn't think it's required.
We would really love to know what some of you pros out there think! Any input would be greatly appreciated.
For the record, we're in Canada so we do get our fair share of nasty winter weather.
Thanks!
blackout is offline   Reply With Quote
Old 09-15-2009, 08:32 PM   #2
Xtreme DIY'r
In the US I&W is required 2' beyond the inner wall as I recall
When they take off the old shingles you should get a better idea of what's under there
Tar paper worked for decades & still works
I&W works better, especially if there is an ice dam
Old 09-15-2009, 08:59 PM   #3
Commercial Roofing
AaronB's Avatar
Not to mention the fact that if there is an old ice barrier, when yu tear the old roofing off, there will be thousands of holes through the barrier, rendering it useless to stop ice infiltration. For an ice barrier to function properly with nails through it, there must be nails filling those voids. The bituthane membranes will seal to the ice barriers.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-16-2009, 10:59 PM   #4
I'm certainly no roofing expert but, I would definitely get new I&W shield put on. For some reason, the roofer you want to go with doesn't want to do that. Don't know why, he'd still get paid for doing it. I had a new roof done two years ago and they took off the old shield and put new stuff up, In fact, they ran it a little higher than usual to be safe, which sat well with me.
OldManJim62 is offline   Reply With Quote
Old 09-16-2009, 11:10 PM   #5
Billy
Send a message via AIM to willcmjr
I wouldn't even consider not doing it. If you're already paying for a reroof, this won't add that much expense in comparision.
However, I think this guy might now know what he's doing. If a roofer told me it wasn't necessary I wouldn't even consider using him/her.
willcmjr is offline   Reply With Quote
Old 09-17-2009, 08:54 AM   #6
MJW
I wonder which one has the best price??????
The guy is actually telling you the truth. I&W is quite over kill for most of it's applications, but why not put it on since you have the roof open? Sure, you can go without it, or use the old stuff, and probably be just fine. Why take the risk though being it can be done so easily.
In the end, if you trust your roofer, trust him. It seems that you are questioning too much already.
MJW is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Ice and Water Shield under drip edge? sutterml Roofing 10 07-11-2011 06:04 AM
Rubber Roof over Ice & Water Shield PerpetuallyRepairing Roofing 23 01-08-2009 11:50 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
