Ice & Water Shield - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2009, 02:21 PM   #1
Ice & Water shield
We have be advised to install the i & w to seal brick towers that have a sloped brick top. This is new construction with apparent wind movement that has caused leaking. Has anyone had good experiences with this and what is the life of the product?
ccr123099 is offline   Reply With Quote
Old 05-26-2009, 04:54 PM   #2
Ice and Water Shield materials are made of bituthane, which, when left exposed to the harmful UV Rays of the Sun, will deteriaorate in a relatively quick time frame.
If left exposed, it would not offer the long term protection you are desiring.
Also, to install it so it remains adhered to the concrete crown of the chimney, if that is what you were referring to, then the cenment surface would need to have an asphalt primer installed first.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-26-2009, 05:19 PM   #3
These towers are part of a commercial building; 28'X 21', with a wood frame and cement board decking. 30 tar paper on the decking then the brick veneer at a 45% slope to the vertical tower wall. The tower has been flashed at the 45% joint where the slope meets the wall but still leaks.
We have been told to remove the brick on the slope and apply ice & water shield to stop the leak. However the sloped brick has a support angle iron that must be bolted through the membrane.
Will this work?
Old 05-26-2009, 10:43 PM   #4
MJW
Underlayment (I&W) should not be used to prvent leaks. The roofing or the cement job is to blame.
Is the flashing in the mortar?
How is the flashing leaking?
MJW is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Rubber Roof over Ice & Water Shield PerpetuallyRepairing Roofing/Siding 23 01-08-2009 10:50 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
