Ice And Water Sheild - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-29-2011, 08:10 PM   #1
ice and water sheild
Can I put ice and water sheild over shingles or is it a waste of money?
angelor is offline   Reply With Quote
Old 08-29-2011, 08:11 PM   #2
Framing Contractor
Rewards Points: 76
It goes under.
sixeightten is online now   Reply With Quote
Old 08-29-2011, 10:34 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
When installing a roof after the tear off.,.,the I&W goes first.If you are recovering a roof (Calm down MJW,Seeyou and others)(Recovers are not recommended) never use anything between layers.That includes felt.IMO
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
seeyou (08-31-2011)
Old 08-31-2011, 09:46 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Be kind of like wearing your underwear outside your pants. It's not against the law, but doesn't quite give the desired effect.
seeyou is offline   Reply With Quote
The Following 4 Users Say Thank You to seeyou For This Useful Post:
josall (08-31-2011), MJW (08-31-2011), Roofmaster417 (09-02-2011), Tom Struble (09-05-2011)
Old 09-02-2011, 10:42 AM   #5
Seeyou
It would be a waste of money. IMO recovering is not a good practice. Do it right the first time.
Roofster is offline   Reply With Quote
Old 09-05-2011, 02:00 PM   #6
Rewards Points: 1,418
The ice and water shield does not stand up to sunlight so it has to be covered (by shingles on top).
The Following User Says Thank You to AllanJ For This Useful Post:
Gymschu (09-05-2011)
