Ice And Sleet Shield Under Rubber Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-21-2010, 02:42 PM   #1
ice and sleet shield under rubber roofing
We are having rubber roofing installed over a flat garage roof - someone has suggested putting the ice shield underneath. Thoughts on this?
sthaney is offline   Reply With Quote
Old 11-21-2010, 04:14 PM   #2
Chicago, IL
Michael Thomas's Avatar
If the "rubber' (modified bitumen?) roof is properly installed, no additional water barrier is required below the membrane.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-21-2010, 06:04 PM   #3
Rubber and mod-bit-2 different animals
johnk is offline   Reply With Quote
Old 11-21-2010, 06:29 PM   #4
Doing This Way Too Long
Rewards Points: 532
"rubber" is a pretty generic misnomer. Regardless, no flat-roof system requires ice/water added as a component.
If your membrane fails, ice/water is going to do absolutely nothing to save you.
OldNBroken is offline   Reply With Quote
