Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-25-2010, 05:45 PM   #1
Ice Shield
Can Ice Shield be use by itself on a flat roof with a little slope and a floating deck put over top of it? Nothing was put on top of the ice schield.
Lacy
lwinstead is offline   Reply With Quote
Old 08-25-2010, 05:49 PM   #2
Ice Shield
you mean exposing the shield to the elements? i dont think so. you need some kind of cap over teh shield.
federer is offline   Reply With Quote
Old 08-25-2010, 06:30 PM   #3
Tom Struble's Avatar
Ice Shield
you have to understand what you will have to do to repair or replace any roof system under a deck,i&W is not a roofing material its a roofing underlayment,your deck is not roofing...get where im going?
Tom Struble is offline   Reply With Quote
Old 08-25-2010, 10:15 PM   #4
Thrasher
Ice Shield
Lacy
Absolutely not. As tomstruble said, ice shield is an underlayment.
Lulimet is offline   Reply With Quote
Old 08-25-2010, 11:14 PM   #5
Ice Shield
Lacy
What I've seen used is a thick sheet of EPDM.
handy man88 is offline   Reply With Quote
Old 08-27-2010, 12:19 AM   #6
Ice Shield
EPDM will work.
Ice Shield would not be a good idea as the edges would be the weak point initially and over time the adhesive backing would lose its grip.
gjjr2001 is offline   Reply With Quote
Ice and Water Shield hansemx1 Roofing 19 11-07-2012 10:32 PM
Termite Shield or Not Ezekiel Building & Construction 2 02-09-2011 08:53 PM
Ice & Water Shield?? blackout Roofing 5 09-17-2009 08:54 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
proper way to install ice - water shield on roofs rjh Roofing 1 06-01-2009 05:38 PM
