Ice Dam Prevention - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-07-2009, 05:16 PM   #16
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Yes, nail through it anywhere but over the metal drip edge.
If there are gutters then yes, you need to heat them with self regulating cable to keep the water flowing to the ground.
As for stopping the melting of snow to prevent the issue, I'm guessing you live where snow doesn't melt, it only evaporates?
Beligerance is not necessary. I answered your question with the truth. There are too may variables to quote a min and max: Drip edge or valley's, How many square feet of coverage, how deep is the over hang, north or south facing, metal or asphalt, metal or asphalt valleys, automatic or manual or both, enough square footage to require separate activation, gutters included.... with zoned controls, ??? etc, etc...
If you don't want anything electric under your roofing, that's fine. The question I have is when you get a call from a potential client who has ice dams and water damage, do you tell them they should have contructed it to your liking and good bye? What's wrong with having an answer that fits the problem that actually works?
Where the problem exists, there is an answer, is all I'm saying.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 01-07-2009, 05:35 PM   #17
the roofing god's Avatar
Send a message via MSN to the roofing god
no one`s belligerent,my customers have no problems with my solutions,the point is that with builtup snow,melting from the bottom up helps feed the water problem,NY gets about as bad as it gets in the US
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-09-2009, 06:47 AM   #18
Good website to understand ice dams and their cause...
Buildingscience.com
Chemist1961 is offline   Reply With Quote
Old 01-09-2009, 09:55 AM   #19
Tom Struble's Avatar
Rewards Points: 2,002
i think its a better solution that zig zag heat cables clipped onto the roof if heating to get rid of ice dams is your only solution
Tom Struble is offline   Reply With Quote
Old 01-15-2009, 06:48 AM   #20
better to staple foam channels under the roof,and spray foam the roof rafters full of foam to keep the roof cold,so the Ice dams don`t form,and they melt off from the sun,from the top down
Ice dam prevention alpercata Roofing/Siding 3 12-31-2008 12:05 PM
Mold prevention over concrete slab leob Flooring 4 05-22-2008 11:13 AM
Termite Prevention powrus General DIY Discussions 8 03-23-2006 09:04 AM
