Ice Dam Melting Pellets. Do They Work? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-15-2010, 06:36 AM   #1
the Musigician
DangerMouse's Avatar
Ice Dam Melting Pellets. Do they work?
I've seen commercials for "toss it on the roof" pellets for ice damming problems.
Have any of you used them? Do they work well?
Any comments?
Thanks!
DM
Old 02-16-2010, 02:28 PM   #2
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
First off that's just a band aid no matter what. Second it depends on the chemical make up of the pellets. Sodium Chloride (Salt) is damaging to the roof as wella s gutters and metal flashings and may void any warranty you have on the roof. While Calcium Chloride is slightly more gentle, you may still want to check with the manufacturer of your roofing products before throwing them up on your roof.
DO they work? Sure, they melt the snow on the ground, why not on the roof. However again it's a band aid approach. The permanent solution is improved insulation, ventilation, and if the ice is working it's way inside the building then also an ice shield beneath the roofing material.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Italy recalls 'radioactive' wood pellets Scuba_Dave Off Topic 2 06-23-2009 08:20 AM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
Hiring guys to do work without a contractor Safe or Not Worth Liability wise? twilightcall General DIY Discussions 1 03-15-2008 08:40 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
