Ice Dam And Leak In Northern Ontario - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-09-2014, 09:39 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
That is not a mansard roof to my eye and the soffits on the 1st floor are not functional nor do they help ventilate the attic.
Old 02-09-2014, 10:30 AM   #17
Ok so I did some research on the house
- the vent sticking out is a b vent (for all my sewage and water)
- the actual attic vents are little squares burried under the snow
- the 'roof' style is a cottage style, so it slopes on all 4 ends, two ends are smaller than the other,
- I have no gable vents and don't have the opportunity to install them either due to the roof style
So the house is a mansard style and the roof Is a cottage style. Piss poor choice for northern ontario. Especially with no adequate vents. Will have to install two twirly birds next spring
Sent from my iPad using Tapatalk
DieselDetroit is offline   Reply With Quote
Old 02-09-2014, 02:54 PM   #18
Rewards Points: 646
Dont bother with whirlybirds or gable vents.
You need a smartvent style intake vent installed along the bottom of the main roof. It is an intake vent that is installed on the roof, that and 5-6 pot vents should be more than adequate for exhaust.
If your main ridge is long enough ridge vent could be used, but at that point you might as well throw a new roof on as well.
PatChap is offline   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
Windows on Wash (02-10-2014)
Old 02-09-2014, 04:28 PM   #19
Just to let u know I currently have 4ft of snow and am expecting at least 2 more before the end of the season. I question if the above method will actually work
Old 02-12-2014, 04:26 PM   #20
Bump
I found a black vent pipe, roughly 1 1/2" going above the leak source. It goes from above my bathroom down somewhere and connects to the rest of the vent system.
There is also am elbow at this point
Is it possible the was the source of my leak? How much would be too much for a vent pipe leak? 1cup, 1 gallon, 10 gallons? It was sporadic and only occurred twice. Once a large amount, second small amount. Days between the two and hasn't occurred since
Same location both times. Straight through the hole going from my ceiling into the attic
Old 02-13-2014, 11:12 AM   #21
Plumbing vents are common leak pathways.
Old 02-13-2014, 05:45 PM   #22
The amount was different both time and sporadic. Occurred one week apart and hasn't since. Are these characteristics typical?
Old 02-14-2014, 08:06 AM   #23
Every leak and situation is different.
