Ice Dam In 70's Home - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-28-2014, 09:45 AM   #16
Considered steaming?
How did this work out for you OP? We recommend not chiseling ice necessarily as it can take parts of your roof or soffit with it! Steaming is the best answer, especially if you have a large area to cover. (qualifications: Minnesota Roofing company Easternroofingdotnet)
Roofing guy is offline   Reply With Quote
Old 03-28-2014, 10:14 AM   #17
Rewards Points: 175
I ended up just buying a snow shovel, pulling down the 1.5-2 feet of snow to expose the ice dams. They eventually melted away nicely, no more water down the side of the house and are entirely gone now. I will just make sure to check it every so often next winter, thanks all .
vivithemage is online now   Reply With Quote
Old 03-28-2014, 11:02 AM   #18
Rewards Points: 1,668
I hope you realize the water that leaked into the structure was under the layer of ice and not on top of the ice. hence: the recommendation for one heat trace cable to melt a drainage channel down to the shingles. Good luck next winter.
SeniorSitizen is offline   Reply With Quote
Old 03-28-2014, 11:04 AM   #19
Rewards Points: 175
Yes, and this is what I saw when I pulled off the 1.5-2 feet of snow that was on top of the ice. This is EXACTLY what was happening:
http://www.icedamcompany.com/wp-cont...anatomy-XL.png
Even as I pulled back the snow, the top part of the ice was still melting/water even though at the time, it was 0F out. The snow insulated it enough to stay warm to melt.
I will just make sure to keep the snow off the roof at that edge of the house.
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 10:55 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 04:28 PM
