Ice & Water Shield...has This Code Been Reinforced In The State Of Ohio? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-04-2010, 02:24 PM   #1
ice & water shield...has this code been reinforced in the state of ohio?
i was told that ice and water shield is mandatory and code for the entire state of ohio. can u tell me where i can find that code and if this is a true statement.
rhonnie is offline   Reply With Quote
Old 11-05-2010, 05:52 AM   #2
Residential Roofer
Slyfox's Avatar
Call your Cities Administration office, they'll send you in the right direction.
Edited to add: residential roofing is a non licensed/regulated trade in our State, so don't expect to much help unless the roof you just had done was new construction, atleast in new construction work there is a framing inspection.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
did my contractor install my ice and water shield correctly? areebis Roofing/Siding 21 07-02-2010 06:54 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
