I Have To Replace Top Seal Plate Any Advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-24-2009, 01:55 AM   #1
I have to replace top seal plate any advice
I have to replace top seal plate any advice.
This is a very old house & the original seal plate is the only plate I believe that is different from modern construction.
My roof also has to be replaced I am a novice do it yourselfer with help from experienced & capable but truly unknowledgeable help.
Could someone give me some advice & simplified & shortened instructions.
thank you.
sharppick is offline   Reply With Quote
Old 04-24-2009, 03:02 AM   #2
Sill or seal?.I would say to remove the old and install the new.You wanted simplified...
johnk is offline   Reply With Quote
Old 04-24-2009, 10:39 AM   #3
Are you referring to the top wall plate?
Do you have any photos that you can upload?
Why does the current one need replacing in your opinion?
Where are you located?
Maybe it would be best if you posted this question in the building or carpentry sub-forum.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-24-2009, 09:53 PM   #4
The old one is rotted & bowed & yes I do mean the top seal plate except with this old house there is no top or bottom plate divided by a a piece of plywood , just 1, 2 x 6.
thanks
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 06:40 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 07:02 PM
to seal or not to seal, this is the question dvarga Flooring 3 08-07-2005 09:21 AM
