I Built My Own Trusses - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-25-2010, 08:32 PM   #1
I built my own trusses
I post awhile back about seeing if anyone on here ever built there own trusses, I got alot of flack about this from people saying I was crazy to stupid for wanting to do this. Well I did it and they are great and very very strongI built my own trusses-0925101914b.jpg
Chriscr is offline   Reply With Quote
The Following User Says Thank You to Chriscr For This Useful Post:
BigJim (09-25-2010)
Old 09-25-2010, 08:41 PM   #2
They look ok to me. Did you save much money by building your own trusses? If you take into account the time spent building them then how does it compare.?
merle is offline   Reply With Quote
Old 09-25-2010, 09:04 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
they can be great money savers if you are where you can get a lot of cut offs of 2X.
a couple things about home built:
they are not engineer certified so a building department may not accept them without an engineers cert.
along that same vein; what the plates are made of and how they are attached may present a problem with the building department as well.
Old 09-25-2010, 09:12 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
and you proved what? exactly
Tom Struble is offline   Reply With Quote
Old 09-25-2010, 10:09 PM   #5
nap
You talking to me?
nap's Avatar
that he could do it.
Isn't that the basis of DIY?
The Following User Says Thank You to nap For This Useful Post:
Tom Struble (09-26-2010)
Old 09-25-2010, 10:24 PM   #6
Rewards Points: 1,088
Is this per code?
I'm not sure whether those wood gussets will provide the long term structural stability that steel ones provide. I don't think I've ever seen a truss manufacturer use wood gussets. I would imagine wood gussets would be cheaper than steel, so if it's ok, then a truss manufacturer would also use nailed on gussets also (no need to buy steel, no need to buy huge presses, etc.).
I assume you used nails instead of screws to secure the gussets. How thick are the gussets?
handy man88 is offline   Reply With Quote
Old 09-25-2010, 10:41 PM   #7
they used wood nailed gussets for over 100 years they use steel now cause it is way faster and the can have a control so all the trusses are alike......but I saved a couple hundred dollars it took time wise if I added it all together i would say 15 hours thats cutting all the wood then putting them altogether after.......I used 1/2 ply nails and screws and alot of glue
Old 09-25-2010, 10:46 PM   #8
All yeah and thanks Nap.........and I do not have to have anything inspected......the truss specs for the lengths were designed by a truss company.......
Old 09-25-2010, 10:47 PM   #9
I assume this isn't planned as a living space with the large door opening and since you didn't extend the trusses to allow soffits to be installed for better heat exhaust.
Old 09-25-2010, 10:53 PM   #10
its a garage and theres 8" topcord overhang
Old 09-25-2010, 10:54 PM   #11
yeah sorry the pics kinda blurred but there will be soffit all around
Old 09-25-2010, 10:56 PM   #12
Why didn't you make the opening big enough for two vehicles to drive straight in?
Old 09-26-2010, 06:14 AM   #13
Chicago, IL
Michael Thomas's Avatar
There's nothing wrong with properly engineered wood truss plates, in fact it's a standard method of truss repair / reinforcement.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-26-2010, 07:56 AM   #14
Design vs. repair are two different things.
Old 09-26-2010, 08:16 AM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 544
I built a few buildings just like this 30 some odd years ago and they are still standing and in good shape today. I also worked in a truss factory for a while when my work got slow and I would put my home made trusses up against any of the factory ones any day. As matter of fact I never did trust the metal gussets as they just didn't look like they would hold under pressure. The metal gussets are for speed and the fastest way to build. If you want to compare the two, nail and glue a 12 inch X 12inch piece of plywood to something of heavy wood then press in one of the metal gussets, now see which is the easiest to get loose.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Building Garage with Engineered Trusses twiles Carpentry 30 03-12-2016 08:17 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 08:47 AM
Joists - TGI vs. Web Trusses handy man88 Building & Construction 3 04-02-2007 11:34 AM
cost of trusses vs stick built ugabulldog Building & Construction 2 10-17-2006 10:15 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
