I Believe Ridgevent Is Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 08:59 AM   #1
Rewards Points: 119
I believe ridgevent is leaking
Got up and roof and above where the leak is coming from, two peices of ridge vent meet each other (seam) I pulled (with little force) on one of the pieces of ridge vent and it just comes up, two of the nails are no longer attached and can just be lifted out of the roof.
This is the first time it has leaked.
My first instinct is that I should just nail it down with two new roofing nails an inch from the old nails and then caulk over the new nail heads and run caulk along the seam of the ridge vent? What do you advise? Ty
SpaceCoast is offline   Reply With Quote
Old 06-06-2013, 08:50 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,002
If you are going up there, use screws.
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
