Hurricane Sandy And Roof Leaks - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-31-2012, 01:50 PM   #1
Rewards Points: 27
Hurricane Sandy and Roof Leaks
Hi,
I was wondering if it's possible that the high winds (and rain) could cause the roof to leak. The builder's "support" person said that it's most likely the wind caused the rain water to blow up the roof which would go underneath the shingles and cause the roof to leak. Is that possible? Would I still need to contact a roofing contractor or do I just contact a drywall contractor? (I'm pretty dumb when it comes to this stuff...)
Another possibility he mentioned was to look at the flash to determine if it's a roof problem? What does that mean exactly?
Should I cut a large hole in the ceiling drywall to let it dry out?
Unfortunately, it's not covered under warranty (expired after one year)...
Thanks!
dajonx is offline   Reply With Quote
Old 10-31-2012, 04:12 PM   #2
Rewards Points: 12,794
In that strong a storm anythings possible.
Might want to concider giving your insurance company a call.
Right not that insulation in the attic that got wet needs to be removed ASAP.
The faster it gets dry the better before mold sets in.
Roofer for the room, sheetrocker for the ceiling.
dajonx (11-01-2012)
Old 10-31-2012, 08:00 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Joe's rigth. Get rid of the wet insulation and get your Ins. Co. on the phone.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
dajonx (11-01-2012)
Old 10-31-2012, 09:02 PM   #4
Rewards Points: 27
Thank you. Sorry for the stupid question, but how do I do that exactly?
Old 11-01-2012, 08:15 AM   #5
Rewards Points: 27
Also, we've called the insurance company and they said that they're first helping out those who have more urgent situations first. So in the meantime, I would like to minimize mold growth ASAP and would like some direction in doing it.
Any help is GREATLY appreciated!
Old 11-01-2012, 08:31 AM   #6
DIY staff
Rewards Points: 7,174
Tarp the area under the wet drywall-----then use a hand held drywall saw and open up the drywall----get that dried out
Find the joists---cut along them----post a picture for the best instructions.
dajonx (11-01-2012)
Old 11-01-2012, 08:58 AM   #7
Rewards Points: 27
Thank you.
Here are a couple of pictures of the two leaks...
Old 11-01-2012, 09:00 AM   #8
Gymschu's Avatar
Rewards Points: 184
I have witnessed storms (these weren't even hurricanes) that literally made the rain blow UPWARDS. The wind, combined with buildings/homes and how they were oriented literally pushed the falling rain back up. This causes all kinds of problems with roofing, windows, really any place that isn't properly waterproofed. I shudder to think what happens to rain in the midst of 100 mph winds.
From the looks of your pics, there has been a leak there before because it looks like someone made a drywall repair in the middle of that one sheet of drywall. Sandy only made the water intrusion worse. P.S. Pics of the outside area where this is occurring would be even more helpful if you can safely access the area.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
dajonx (11-01-2012)
Old 11-01-2012, 09:01 AM   #9
DIY staff
Keep trying-----I'm off to work,but others can help---Be careful of wires or pipes---that's why I suggested a hand held saw---
dajonx (11-01-2012)
Old 11-01-2012, 09:06 AM   #10
Rewards Points: 27
Boo yah! I got the pictures to show!
Ok, thank you!
Old 11-01-2012, 10:34 AM   #11
Rewards Points: 27
Great, that (the drywall repair) was there when we first moved in (new townhome). I didn't notice it until much, much later. I can try to take some outside pictures when I get home later today.
Is this a good process?
  1. Turn off electricity to garage
  2. Place tarp on ground
  3. Wear goggles, gloves, respirator, long sleeve clothing
  4. Cut out drywall ceiling between joists
  5. Pull out wet insulation
  6. Throw drywall/wet insulation out in garbage can
Is there anything I should be careful of (ie, handling wet insulation, etc)? How do I determine if the insulation is wet (any discoloring or anything)? Is there a way I would know if mold is present? If so, what should I do then?
What exactly is "blown fiber glass"? Is that loose insulation and going to get all over the garage?
Thank you!
Old 11-01-2012, 09:21 PM   #12
DIY staff
That will come down in a big heap----lay down sheets of heavy plastic----that will help with the clean up---
Those entire sheets will drop----take pictures for your insurance company.
Old 11-02-2012, 08:17 AM   #13
Rewards Points: 27
Here are some updated pictures...
Outside:
Is this the culprit?
Old 11-02-2012, 08:24 AM   #14
Rewards Points: 27
So I made a hole in the drywall and found out there isn't any insulation in the ceiling. At least not in that part of the garage ceiling... I also found out that there is a cinder block behind the drywall ceiling where the drywall patch was made... That really angered me as that could've dropped on my car, wife, and/or baby. And when they were building it, they must've noticed the drywall cracking since they patched it up with tape and spackle as you can see from the pictures below. You would think they would've investigated a bit to see what was making the drywall crack open... So furious about that.
Here are some pictures:
Inside the ceiling:
As you can see, there's no insulation... Why is there so much debris? Is that normal?
Old 11-03-2012, 08:21 AM   #15
DIY staff
Nothing unusual about the debris---looks like some insulation blew in when the adjoining attic or walls received insulation.
Garages are seldom insulated by the builder----not need unless the garage is to be heated---
Hurricane Sandy got me nadorp General DIY Discussions 34 12-09-2012 11:12 AM
