How Would This Siding Set-up Work - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-03-2013, 12:42 PM   #1
Rewards Points: 274
how would this siding set-up work
I want board and batten siding and plan on using 3/8 treated composite (smartside) siding over foam sheathing. If I nail the battens to this, I can hit solid wood on top and bottom plates, but do you think in between will spiral shank nails hit enough to hold and not pop loose?
ugabulldog is offline   Reply With Quote
Old 09-03-2013, 01:03 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
are you using wood sheathing or just the foam sheathing to cover the wall studs?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-03-2013, 01:28 PM   #3
kwikfishron's Avatar
Rewards Points: 90
Originally Posted by ugabulldog View Post
If I nail the battens to this, I can hit solid wood on top and bottom plates, but do you think in between will nails hit enough to hold and not pop loose?
The battens need to hit the studs so whether you go 16" or 24" oc will be dictated by how the wall was framed.
kwikfishron is offline   Reply With Quote
Old 09-03-2013, 02:17 PM   #4
Rewards Points: 274
Old 09-03-2013, 02:21 PM   #5
Rewards Points: 274
I know it will work if I use osb sheathing behind the siding instead of foam, but I would really like the little extra r-value plus I am looking at quiet brace sheathing for sound proofing.
Old 09-03-2013, 04:39 PM   #6
Rewards Points: 90
You are correct that is what I'm saying especially if the smartside is only 3/8. The 3/8" is used for soffit and not siding btw.
Did a pretty good job of decoding those dashes there, didn't I.
Old 09-03-2013, 07:33 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
why arent you using a rain screen as well over top of the foam.. youll have an air space for water to drain down the wall plus the vertical strapping will be nailed solid through the foam into the studs.. then nail the siding to the furring strips
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (09-04-2013)
Old 09-03-2013, 08:31 PM   #8
Roofmaster
Rewards Points: 2,172
I am not a siding expert, but it is my opinion that you should always use a system that sheds water. Board and Batten is commonly used on barns and outbuildings that are often built on grade beams, or in pole barn fashion where a little moisture intrusion now and then is acceptable. Will this system have secondary moisture protection like house wrap? If I was doing this i think I would picture frame, then run 2 x 2 (Nominal) horizontal Pressure treated nailers to provide good anchorage for the vertical siding. Install rigid Iso foam between the nailers that are fastened to the studs, then house wrap then your B&B. Pop chalk lines at your nailers before you install siding.
Old 09-04-2013, 12:16 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Winner right here.
The foam is fine and as long as you hit the wall framing, you are good. Be sure to use a foam with a good compressive strength.
Be sure to apply a house wrap as well as bug screening on the top and bottoms.
Old 09-04-2013, 04:38 PM   #10
for vertical siding ill run the rain screen furring strips diagonally,, where some will do it horizontal.. if you run it horizontal youll create a ledge that water sits on and doesnt drain.. diagnal allows for drainage
Old 09-04-2013, 09:47 PM   #11
Roofmaster
Even with Tyvec under the siding? seems like it would be hard to hit the nailers on an angle like that but I believe you, I just would not do it. I would probably use D226 type 1 felt instead of Tyvec in this situation though.
Old 09-04-2013, 10:18 PM   #12
hows it hard to hit the nailers.. you can see exactly where its at as you work your way along the wall putting up siding
Old 09-04-2013, 10:59 PM   #13
Roofmaster
There is secondary moisture protection over the horizontal nailers with foam in between them right? Maybe I'm confused. Ive been getting dizzy when I stand up fast.
Old 09-05-2013, 07:12 AM   #14
Rewards Points: 894
Negative.
Moisture protection and/or foam are beneath the nailers James.
The Following User Says Thank You to Windows on Wash For This Useful Post:
jagans (09-05-2013)
Old 09-05-2013, 04:55 PM   #15
Registered User
Rewards Points: 4,924
How thick is the siding; 5/8"? How long are the fasteners? How much rainfall annually for your location? http://www.srh.noaa.gov/images/ffc/gapcpn.gif
A draining housewrap may suffice. Page 6; https://docs.google.com/viewer?a=v&q...RvUBSlz4b5thmA
Especially with foamboard (faced ?) to stop any south-facing moisture drives protecting the wood frame wall. Any overhangs on the roof to protect the walls/windows from rain?
Gary
How many hours to do this work? brainfogbetty Drywall & Plaster 17 10-26-2011 05:17 AM
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 06:03 PM
hardie plank siding bob fortier Carpentry 4 05-31-2010 08:01 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
