Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-05-2012, 12:28 PM   #31
RFN-4A-LVN
Roofmaster417's Avatar
how would/should they do this ?
Originally Posted by mae-ling View Post
This is more of a carpentry job then a roofing job.
Carpenters deal with the structure, and some will shingle also. Roofers deal only with the shingles.
I have taken on a couple and they turned out very well.I was smart enough to have a close friend who is a custom home builder set in with me during the rebuild phase.
I do have extensive carpentry skills but being a Moisture Penetration Prevention Specialist is my profession and not so much with carpentry.
Roofmaster417 is offline   Reply With Quote
Old 11-06-2012, 09:36 AM   #32
You might be able to get away with sistering the rafters from the inside. The bowed rafters can even be unbowed at that same time. I have TONS of experience with doing this. Lets see some pics of the attic. As for professional roofers wanting to push rafter work off their plate - SHAMEFUL. Sometimes when doing a reroof, the total picture of whats going on will not be obvious untill the tearoff is well underway. This is especially true for flat roofs that dont have attics or easy access to inspect beforehand. Since the roofer wont want to deal with bad rafters, we need to make arrangements ahead of time with a carpenter to be on call and ready to change horses in midstream with the roofer in the event rafter repair is needed. I'd rather have the a roofer that understands and can do the whole roof job - including rafters.
Hates my roof is offline   Reply With Quote
