How To Terminate Steel Roof Cap Into Cross Gable With Out Leaks? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 08:56 PM   #1
How to terminate Steel roof cap into cross gable with out leaks?
I have done many shingled roofs with the cross gables with out issues.. but residential steel (pro rib) is new to me as far as valleys go.. I have a 6/12 pitch cross gable terminating at and about 3ft below the 12/12 roof. Im a little confused as to how the ridge cap terminates at thus location and sheds water from the 12/12 roof? As the ridge cap will be up against the ribs the panel.. do i make flashing and caulk everything? Any ideas or picks will be appreciated..
rusticlife is offline   Reply With Quote
Old 04-02-2013, 10:21 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
If you propery scissor-lock the valleys together like they normally get locked together, everything should fall into place with little to no caulk.
How to terminate  Steel roof cap into cross gable with out leaks?-scissor-locking-valleys.jpg   How to terminate  Steel roof cap into cross gable with out leaks?-scissor-locking-valleys-2-.jpg
tinner666 is offline   Reply With Quote
The Following 2 Users Say Thank You to tinner666 For This Useful Post:
jagans (04-03-2013), Windows on Wash (04-03-2013)
Gable roof leak between plywood -PICS Tryskylife Roofing/Siding 16 09-13-2012 06:11 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
No Gable Roof Access 1Logan Roofing/Siding 3 03-18-2012 11:18 PM
Gutters: Joining two gable roof planes together funnels water into the corner AlexHouse Roofing/Siding 6 03-12-2012 06:52 PM
Cross Gable roof porch addition ehowardal21 Building & Construction 1 09-03-2009 04:10 PM
