-   -   How to terminate Steel roof cap into cross gable with out leaks? (http://www.diychatroom.com/f9/how-terminate-steel-roof-cap-into-cross-gable-out-leaks-176141/)
rusticlife 04-02-2013 08:56 PM
I have done many shingled roofs with the cross gables with out issues.. but residential steel (pro rib) is new to me as far as valleys go.. I have a 6/12 pitch cross gable terminating at and about 3ft below the 12/12 roof. Im a little confused as to how the ridge cap terminates at thus location and sheds water from the 12/12 roof? As the ridge cap will be up against the ribs the panel.. do i make flashing and caulk everything? Any ideas or picks will be appreciated..
tinner666 04-02-2013 10:21 PM
2 Attachment(s)
If you propery scissor-lock the valleys together like they normally get locked together, everything should fall into place with little to no caulk.
