How To Terminate Metal (w) Valley At The Top - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-16-2012, 07:14 PM   #1
How to terminate metal (w) valley at the top
What's a good way to terminate a metal valley at the top?
If the "w" type metal valley extends to the ridge there is a large open hole in the shape of a triangle at the top.
I've been cutting, or darting, the metal with tin snips to fold (mashing, really) the sheet metal over some caulking, nailing it down and running a tin or comp shingle over that and, then, running the ridge caps over the top.
Would it be better to extend the valley above the ridge or top of the house, whatever, then, cut to flatten out the metal for running over the ridge to the other side and nailing it down?
Thanks.
yawni is offline   Reply With Quote
Old 04-18-2012, 12:37 PM   #2
43 years in construction
Arkitexas's Avatar
Yawni,
Not many people use sheet metal valleys these days and the art of sheet metal work is fading away. The apex of two meeting valley flashings is a two or three piece assembly that is soldered together depending on whether the valley is "V" or has a folded ridge ("W") profile. This not the same kind of soldering you would do with a regular soldering gun. Any sheet metal shop worthy of their name can fabricate one for you. All they need is the pitch of both the main roof and the gable as well as the width of exposure and the shingle overlay. Take a piece of your valley flashing so they can match the profile. Don't do it with caulk unless you want a guaranteed future leak.
Rick
Arkitexas is offline   Reply With Quote
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Exposed sheet metal questions ohman Roofing/Siding 6 12-31-2010 10:46 AM
Standing seam metal in NJ pcampbell Roofing/Siding 1 05-12-2009 07:10 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
