Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-08-2009, 04:27 PM   #1
Learning by Doing
Leah Frances's Avatar
Exclamation
How to temp patch garage roof leak?
My detached garage roof is leaking. Ceiling stains indicate that the former homeowner ignored this for some time. I need to learn how to temporarily patch the roof to stop the water intrusion until the spring when I can tear the whole mess off and start fixing some of the BIG problems.
Here are some pics:
Could this be what is causing the internal leaking? Do I just hammer the nails in?
What about this broken board inside the attic? It doesn't seem to show water damage around or under it.
I'm nervous about walking around on the roof because of things like this.
The carpenter bees I had exterminated last summer were clearly there for more than one year.
There does seem to be water damage associated with this insect damage.
I ranted about this before x-mas, now I need to do something to stop things from getting worse. Thoughts?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-12-2009, 03:13 AM   #2
I didn't see any pics of the garage i think although someone has definitely tried to hammer through on the broken 1x8.
Anyway, yes you have a big project coming as a homeowner that has rotted rafter tails, 1x8 etc.
If this is near a wall i would suggest you hire a competent roofer as when you try to repair, you may have a waterfall coming in. Just my 2 cents
Just a roofer is offline   Reply With Quote
Old 01-15-2009, 06:54 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
those nails are from what we call the valley area,and they are too close,you can try knocking them down,and sealing the nails,then clear the leaf debris from the edge of the overlapping shingles,and heavily tar that edge/line where you see the cut shingle edges-That may buy you some time,but it`s a band -aid,You need a professional to fix it right
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-15-2009, 09:46 AM   #4
Learning by Doing
Thanks - as soon as the weather warms up above freezing I am going to deal with the nails, clean things up, and tar over the lot. Hopefully, it will hold us to spring.
Then we have to decide if it is worth it to rebuild the joists or if we should tear down and start fresh.
More On This Topic
Don't forget about Fido when cold weather comes, especially if he prefers to be outdoors year round. Though dogs have coats and can usually tolerate cold weather well, intense cold is not good for your dog. Having shelter for him may not be enough. You... Read More »
A bubble is an unsightly blemish that pops up on your roll roofing, like acne. Sometimes it shows up after the roof has been down a while. Sometimes an imperfection in the roof under the roofing causes the bubble to appear. Whatever the case, a bubble... Read More »
Patching a flat roof may not seem like much fun and you may be tempted to call in the experts. There are several roofing companies that only do flat roofs because of the lower amount of work involved. But you can patch your own membrane roof if you have... Read More »
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
Water damage can ruin any new remodeling project. Learn how to guard your remodel from potential loss from water destruction from a home staging expert in this free video. Read More »
garage roof leak Chicago Bill Roofing 8 05-05-2009 02:07 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 02:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
