How Tall A Ladder For 2 Story Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 10:57 PM   #1
How tall a ladder for 2 story roof?
The recent store made me aware of two leaks in the roof. Both leaks seem to be coming from the plumbing vent pipe. Which is PVC in my 11 year old house.
Each floor is 8' tall ceilings.
Would I need a 24' or 28' ladder for this?
CZ DIY is offline   Reply With Quote
Old 09-09-2010, 11:15 PM   #2
Doing This Way Too Long
Rewards Points: 532
Extension ladders reach approx 3' less than their described height.
OldNBroken is offline   Reply With Quote
Old 09-10-2010, 12:06 AM   #3
Rewards Points: 978
i used a 16ft to go up one level, so i say at least 26 28 for 2 levels
federer is offline   Reply With Quote
Old 09-10-2010, 08:28 AM   #4
Depends upon attic space & roof
One side of the house I need a 40' ladder due to a walk up attic
Also depends if you need to reach the peak
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Tom Struble (09-10-2010)
Old 09-10-2010, 07:42 PM   #5
Registered User
Rewards Points: 526
Tie the top if the ladder off for stability and wind loads. Secure the ladder bottom to prevent movement on a slippery surface, flip the bottom dirt grips down for sod. Extend the top 3' over the gutter.
http://activerain.com/blogsview/1627...f-if-you-fall-
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 09-10-2010, 08:22 PM   #6
Rewards Points: 1,088
I would go with the 28' as you'll need to factor in the grading around your perimeter and also the angle you'll have to lean your ladder with against the house for safety.
I personally have a 32' Werner and wish I had bought a 28' instead, but they were out of stock and all ladders were $50 off. Luckily I was able to strap it onto the roof rack of my SUV with no issues, but handling the 32' ladder requires up to 2 people.
handy man88 is offline   Reply With Quote
Old 09-10-2010, 08:23 PM   #7
Gary
I've seen the satellite tv guy with his ladder that has hooks on them that hook into the gutter. I haven't been able to find the hooks anywhere.
Old 09-10-2010, 08:37 PM   #8
I usually just pack around a 28',Its usually all I need for residential.
johnk is offline   Reply With Quote
Old 09-10-2010, 10:48 PM   #9
Registered User
Rewards Points: 526
Those hooks are for phone and cable lines, not gutters.
Gary
Thurman (09-13-2010)
Old 09-11-2010, 08:02 AM   #10
Gary
To get the job done, as for most contractors, the only rule is that there are no rules.
Old 09-12-2010, 11:41 AM   #11
Tom Struble's Avatar
Rewards Points: 2,002
have you ever been up that high on a ladder before?if not whatever ladder you choose make sure there is someone else there
Tom Struble is offline   Reply With Quote
Old 09-12-2010, 04:03 PM   #12
kwikfishron's Avatar
Rewards Points: 1,008
These work great for “hopping over” a gutter and stabilizing the ladder.
A 28 ‘ will get you on most 2 story roofs at the eaves. A lot of the times you can’t get the proper ladder angle with a 24”
How tall a ladder for 2 story roof?-quickclick-stabilizer-bar-lss-_i_lbm61342s.jpg
kwikfishron is offline   Reply With Quote
Old 09-12-2010, 04:22 PM   #13
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If they are at the top of the side rails, these are not proper to use for this. The ladder should extend at least 3 feet above the landing you are climbing to. The hooks are used for hooking the ladder on a roof peak or on wires.
and now I see GBR already posted this info
Old 09-12-2010, 04:25 PM   #14
nap
You talking to me?
nap's Avatar
sorry, especially since you are speaking of commercial use, OSHA would tend to disagree with you. No sense in working stupid if it causes injuries.
Old 09-12-2010, 06:10 PM   #15
i agree,no rules will get you hurt sooner or ladder
EPDM Roof Plans stubits Roofing/Siding 44 04-30-2010 11:06 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
sagging roof on a 1.5 story house rootdown003 Roofing/Siding 6 02-20-2009 11:07 AM
Short ladder on roof? firsthomegal Painting 6 06-17-2007 09:30 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
