#1 |
How to sheet and shingle a shed roof
I built a 6x15 foot firewood storage shed and would like info on how to sheet and shingle it. It has 2x6 rafters 16 inches on center and I dont know anything about roofing.
What type of sheeting and nails or screws would I need and how to space the above. Any help is greatly appreciated. Thanks Shipper |
#2 |
This will probably be where I open my mouth and you can tell I don't know what I'm talking about, but anyway, I'm not sure you have enough support structure to be placing too much weight on the top, maybe consider using a tarp.
LIVING THE DREAM |
#3 |
I want to clarify my above comments, rather then editing. I don't have the knowledge to know for sure, but the stated wood shed doesn't appear strong enough to hold the weight of a roof, hense my comment about using a tarp, rereading my comment, it didn't seem right to me. I certainly meant no offence.
LIVING THE DREAM |
#4 |
Super Moderator
1/2" cdx 4-ply plywood as a minimum, fastened with 8 penny nails every 6" On Center on the 4 foot end sides through the rafters and every 12" On Center on and through all of the intermediate rafters.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 | |
How to sheet and shingle a shed roofQuote:
#6 |
How to sheet and shingle a shed roof |
#7 |
registered
its ok its sitting on cement pillings. So what there 16 inchs on center. I would climb up there. But i weigh 190. Do like ed said 1/2 cdx plywood making sure you stagger. Its not rocket science just lay the plywood out nail it down like ed said above. Go straight across starting at top working down to bottom. Making sure you stagger second row so the seams don't line up.
#8 |
Super Moderator
Also, along the rake edges of the structure, prior to installing any plywood, you need to build a ladder for your soffit overhangs.
Thats what I call it, but there might be a more professional term. That is the installation of short 2"x 6"s protruding out sideways, so that the final rafter and fascia can be attached. If you install your plywood on now, your overhang to get past the exterior wall will have no support. Ed
#9 | |
#10 | |
Super Moderator
The Ice and Water Shield's primary benefit is to prevent leaks from Ice Dams and this being just a shed building and not heated, there should never be any Ice Dam occurrences. Ed
#11 | |
In Michigan, no one has used anything but osb for years, It's always covered by roofing, siding or carpet ect..
#12 |
I once experienced a blizzard in Indiana! Had a foot of snow over-night!
With this in mind, I doubt that the beam is adequate for the snow load. In my area, not far removed from Indiana, my shed roof required three, 2X10's over a 10' span,to make a suitable beam. |
#13 | |
My roof has 12 2x6's over a 16ft span and will have a 3/4 inch roof as of tomorrow afternoon. Its only a firewood shed, not the HILTON. ![]() Shipper |
#14 | |
#15 | |
![]() Shipper |
| Display Modes | |
| Replace whole roof or half roof?? | jdsong | Roofing/Siding | 6 | 03-16-2008 12:20 PM |
| Attaching Roof to side of home | joe3534 | Roofing/Siding | 1 | 04-29-2007 10:54 PM |
| Old Wood Shake Roof | Eddie | Roofing/Siding | 9 | 09-15-2005 10:00 PM |
| Where flat roof meets shingled roof | bstyer | Roofing/Siding | 1 | 07-07-2005 09:34 PM |
