Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-15-2012, 02:20 PM   #1
How to seal metal roof seams from outside
I have a 20' X 40' "lean to" cement block workshop attached to my barn. I say "lean to" but the slope is almost nil. (there is SOME slope, but not much). It is leaking like crazy. It had a metal roof installed on top of the old shingle roof probably 10 years ago or so. (also a layer of pink foam board between the old shingle and metal roof). All the stepped lap seams were never sealed with sealant tape. Should I seal all the lap and seams with a sealant??...I found a product online called Henry 295 Metal Roof Seam Sealer but can't find it anywhere...any advice out there??
jtrom is offline   Reply With Quote
Old 10-15-2012, 02:24 PM   #2
Do all the sealing you want but it's still going to leak.
A metal roof like that needed a min. of a 12-2 pitch if not it's going to leak.
If just nails were used and not the metal roof screws with washers that were not over torqed breaking the washer it's going to leak.
Got a picture?
Old 10-15-2012, 03:53 PM   #3
Here are the pics. The roof is fastened with exterior screws with a rubber gasket.
How to seal metal roof seams from outside-imag0548.jpg   How to seal metal roof seams from outside-imag0549.jpg   How to seal metal roof seams from outside-imag0550.jpg   How to seal metal roof seams from outside-imag0551.jpg   How to seal metal roof seams from outside-imag0552.jpg
Old 10-15-2012, 04:31 PM   #4
I'm not seeing how a roof built like that is not going to leak.
It should have been built so the rafters were sitting up on the old garage roof to give is some slope.
Old 10-15-2012, 04:50 PM   #5
I know....is it hopeless?
Old 10-15-2012, 05:09 PM   #6
Moderator
kwikfishron's Avatar
Replacing the screws with new and use butyl tape between the laps is what I’d do short of replacing the roof
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 10-15-2012, 05:24 PM   #7
Where the two roofs meet is your problem
redman88 is offline   Reply With Quote
Old 10-15-2012, 06:56 PM   #8
What can I do?...Tar it where the metal meets the shingles? (go all the way up 3 shingles high):....or put in a wider flashing there?
Old 10-15-2012, 08:35 PM   #9
I guess proper flashing over the metal and at least one row of the shingles
Old 10-16-2012, 01:31 AM   #10
I know alittle about alot
JWilliams850's Avatar
just from looking at the pictures the transition flashing doesnt look like it runs up the shingle roof far enough.
JWilliams850 is offline   Reply With Quote
Seal Leaky Garage Roof from Within? Boiler98 Roofing 4 03-11-2012 05:22 PM
not venting a metal roof penny0322 Roofing 6 03-25-2011 06:39 PM
corrugated metal or standing seam for irregular roof? nicole21 Roofing 6 09-08-2010 03:58 PM
venting from mobile home through new metal roof jeanmoon Roofing 2 07-27-2010 09:39 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
