How To Repair Termite Damage Ė Rafter Ends (outriggers) - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 01:57 PM   #1
Rewards Points: 34
How to repair termite damage Ė rafter ends (outriggers)
I have major termite damage on three rafter ends. The ends canít be sistered because of the extent of damage. The rafters canít be replaced through the attic, because this area of the house has a vaulted ceiling. The rafters (outriggers) need to be replaced to hold a new fascia, there is no water damage.
It looks like I will need to pull the top of the roof back and remove the plywood sheeting to access the rafters for replacement. These rafterís are on the side of the house and will be short, and end at the first truss. The Ridge board above the rafters is solid with no termite damage.
Iím looking for some guidance before I do this. I have no problem with re-roofing this area so thatís not a concern. However, it looks like I need to buy new replacement shingles. I canít get the current shingles off without damaging them. They are a cheap 3-tab that was installed ten years ago (previous owner). Iíve tried to carefully pry the fastener up but the shingles are just two thin.
Here is my question
1. Do I need to remove all the shingles off the sheathing and pull up the sheathing in one piece Ė like it was put down, to access the rafters? Or can I cut the sheathing down the middle of the first or second trust beam to access the rafters. This will save me from removing a lot of shingles.
I think I also need to remove the Ridge shingles to be able to access the top rafter below the Ridge board.
Any guidance would be most helpful.
jeffa123 is offline   Reply With Quote
Old 06-06-2013, 02:25 PM   #2
Rewards Points: 12,882
Those shingles will come off, I'd measure up about 6' and use a flat bar, (wonder bar) and just keep repeatly trying to jam it in under the shingle while holding the bar flat againt the roof.
Remove one one row and use a shingle shove to remove the rest. Once the shingles and paper are off Then you can start removing the sheathing.
I use a Gutster pry bar to pop off the sheathing.
http://www.thegutster.com/
Old 06-06-2013, 02:56 PM   #3
Rewards Points: 34
I was using a wonder bar to remove them. I had no problem sepearating the tar. But the shingle was damaged on the first nail removal. I believe the nails will come up better with the two layers of shingles under them versus the nails with just one level of shingle. (where I started).
Old 06-06-2013, 04:41 PM   #4
Roofmaster
Rewards Points: 2,172
Have you determined the route the termites took to get there? I suspect through furring behind the stucco? Was the stucco taken right down to grade? Termites love that. Have you looked at the sole plates and studs? That is very serious damage, and might go quite far. I would just tear off that whole side, as getting shingles to match is going to be hard, due to fade. If they have gotten into the rafters above the top plate, the rafters are toast. This could snowball. My dad and I started on the rear door jamb of my aunts house down the shore and ended up jacking and ripping out the whole back wall. Those little ........, can be a .........
Old 06-06-2013, 07:15 PM   #5
Metal Roofing
Rewards Points: 600
Originally Posted by jagans View Post
This WILL snowball
There i fixed it.
With the extent of damage we are seeing, your looking at the tip of the iceberg that will need to be done.
AndyWRS is offline   Reply With Quote
Old 06-06-2013, 07:27 PM   #6
Since the poster did not add there location to there profile, just going to have to guess on what type termites they may be.
No all termites have to return to the ground to there nest.
Mostly in the south there termites that life in the house all the time and can show up any where. That's why there homes get tented to kill them, while other areas have the soil treated.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jagans (06-08-2013), MTN REMODEL LLC (06-24-2013)
Old 06-06-2013, 09:57 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
I want to see what the inside of that wall looks like.
Old 06-07-2013, 01:56 AM   #8
Rewards Points: 34
I up-date the profile. The property is in Orange County, CA
I replace two rafters in the garage that looked just like the rafters in the photos. They were easy to replace in the garage. The damage did not continue very far beyond the wall.
Also I did some electrical work on the inside of the wall below that damage(near the floor). The two studs I had access to were fine.
The stucco starts about 8 inches above the concrete pad and foundation.
Yes, it will be interesting to see what's under the sheathing, Then I can decide if I need to open the wall.
Thanks for your help.
Some additional info. I've been all over the house looking for termite damage. For the most part the damage has been isolated to a few area's. They seem to have left the 2x12 trusses alone (ends, attic, garage) were I have access. There are some 2x4 damage in the front corners of the garage. I'm going to sister or replace with pressure treated wood. Also, the house was built in 1978.
I live in a house in the same area that was built in 1964 and I have discovered that there is a big difference in the quality of lumber from 1964 to 1978. The only termite damage in the 1964 home is in the Fascia corners. I replace these corners about ten years ago (cut a foot off in each direction). needless to say the termite's enjoyed the new wood and stopped when they reached the 1964 wood. I learned a big lesson to use redwood on those corners or any rafters that I replace in the future.
My next-door neighbor in the 1964 house just had a new roof put on and had all of the old fascia removed (he had the same corner damage I had). It will be interesting to see how long the new wood last.
Thanks Again
Old 06-23-2013, 02:31 AM   #9
Rewards Points: 34
I have attached photo's showing the rafters inside the house. The damage was only on the out-side exposed wood.
I do have a question I hope someone can help me with. Can I re-use these Shingles. They are a cheap shingle (last owner installed 9 years ago). Can I drive a nail one inch to the side of the hole. and seal the old hole with tar? About half these shingles were torn at he nail head. The shingles were just to thin.
Old 06-23-2013, 09:09 AM   #10
No way would I ever suggest reusing any shingle that's been removed.
Do you really want to have to go back and be redoing all this over again when the roof leaks or shingles blow off?
Windows on Wash (06-23-2013)
Old 06-23-2013, 03:28 PM   #11
Metal Roofing
Rewards Points: 600
Shingles are cheap, take a sample of what you have to the local supplier (The big box store may even have what you need) But to be safe i would go to ABC supply or if your near Oange, Christian Building Materials. Either of them should have what you need, just go to whomever is nearst your location.
Some areas of OC are really notorious for extensive termite damage. I could tell by the pic you were in OC, i see that weekly on our jobs. Just did a repair behind a chimney in Tustin, found lots of live termites during the demo also...that i dont see much, its usually just old damage.
Old 06-24-2013, 01:17 AM   #12
Rewards Points: 34
I wasn't sure if I could find replacement shingles that would be a close match. Thank you for the advice and recommendations. I'll replace these shingles. I appreciate your help.
Old 06-24-2013, 03:29 PM   #13
Rewards Points: 34
On the other side of the home there is termite damage on the underside of one rafter. The bottom half. This appears to be old damage. The rafter still has good support left, but it looks bad.
Any suggestions?
  • I hate to pull the roof back to fix one rafter.
  • I donít want to cut it out. And replace with a fake rafter end. (to make it look better)
  • Using Bondo on this would be difficult.
Iím prepping this home so I can paint it. Any suggestions on how I can make this one rafter more pleasing to look at?
Old 06-24-2013, 09:16 PM   #14
Metal Roofing
Rewards Points: 600
Bondo or a fake tail is your only option if your not removing the roof.
If it is too heavily damaged bondo can be far more work than a fake tail. The fake tail option is sooooo common around here i would just go that route depending on the amount of damage. Provided the rafter to the RT and LFT of it are solid it is your best option. Multiple fake fails in a row are a really bad idea.
The fake tail assumes your able to cut the existing tail back enough to get to solid wood. If you cut it back and the damage continues beyond the fireblock your kinda screwed. It is still doable, but it will end up taking far more time and effort.
I am torn between the two, without seeing it its hard to say which is your best option really.
The Following User Says Thank You to AndyWRS For This Useful Post:
Old 06-25-2013, 01:14 AM   #15
Rewards Points: 34
I think I'll try a fake tail. I didn't know if this was acceptable or not.
I was thinking of bending some tin or aluminum or galvanized metal into the shape of the bottom of the rafter end and screwing it into the bottom of the rafter to hide the sides and bottom damage.
Not sure how well the primer and paint would hold. Wouldn't this hide the damage and look like the rafter after it's painted? As well as maintain the support of the top half of the rafter that's in good condition.
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 11:00 AM
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 05:14 PM
Split Rafter Repair Questions. errodr Roofing/Siding 4 04-04-2008 11:30 PM
Structural Damage repair hcr250 Building & Construction 6 02-02-2008 04:34 PM
Roofers.. Repair inside damage from re-roof? ShortEdged Remodeling 13 12-28-2007 07:58 PM
