How To Repair A Portion Of Aluminum Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-27-2011, 06:08 PM   #1
How to repair a portion of aluminum soffit
I would appreciate knowing how to remove a section of aluminum soffit that was damaged by the previous installation of a steel post which held a old TV dish, through the roof.
The steel post has been removed and the roof has been repaired, now I'm left with a 6" hole in the soffit. I have a new piece of aluminum soffit but I am unsure on how to remove the existing damaged section and reinstall the new section.
Any suggestions on how I should tackle this job, would be appreciated.
Harry
Prodell is offline   Reply With Quote
Old 07-27-2011, 06:13 PM   #2
Framing Contractor
Rewards Points: 112
If the damaged piece is near the end, you may have luck replacing it. If it is in the middle, it will be very difficult. You may have to remove all the pieces next to it and work your way back to the end. Soffit panels are locked together much like siding. Vinyl is more forgiving and can often be popped out or in. Aluminum will bend if this is attempted.
sixeightten is offline   Reply With Quote
Cutting Aluminum Soffit RAS Building & Construction 3 06-14-2011 03:18 PM
to soffit or not to soffit timbo59 Building & Construction 18 08-12-2010 05:07 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
