Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-13-2009, 03:48 PM   #1
How to repair hole in Standing Seam Metal Roof
Hi,
I have an outbuilding that has a standing seam metal roof. During a recent storm tree limbs fell on it and one of them punctured the roof. It's a small hole — 3" in diameter — and I wonder what is the best way to fix it?
Should I replace them entire length of the channel, or just get some self-adhesive peel-and-stick aluminum and slap it on? Or something else? What's the recommended fix for longevity?
Thanks in advance for any advice or help.
DaveMorris is offline   Reply With Quote
Old 04-13-2009, 06:17 PM   #2
Tom Struble's Avatar
fix any holes in the underlayment then replace it
Tom Struble is offline   Reply With Quote
Old 04-13-2009, 10:02 PM   #3
Pro Slate Roofer
tinner666's Avatar
I don't think I could explain it all. Here's a link to a recent one I just did. It might show enough detail so you'll be be able to understand how to unlock the seams and fit in a new panel. http://www.albertsroofing.com/Tin%20...to_gallery.htm
Don't worry about the underlay if any is there.
Frank
tinner666 is offline   Reply With Quote
Old 04-18-2009, 12:40 PM   #4
Interesting question you posted. Concerning whether to patch or totally replace, consider how you want the building to look long-term. Obviously, a patch is not going to look as nice. Standing seam should have no nails showing and it is expensive to replace. Standing seam requires special tools & equipment and around here, they cannot be rented.
Your idea of using self-adhesive aluminum should work although it may have to be replaced every few years. You may also consider using a sheet metal patch anchored in place with screws or rivets. A generous quantity of silicone or other high quality caulk underneath the perimeter of the patch should help prevent leaks. Use enough caulk so that it squishes out from underneath then tool down the caulk around the perimeter of the sheet metal patch forming a tight seal.
Hope this helps,
mold removal
Electrical contractor Atlanta
Epoxy coating
jeck15 is offline   Reply With Quote
Old 04-19-2009, 12:18 AM   #5
Super Moderator
A well written and properly descriptive and thought out response.
Good Advise.
Ed
Hope this helps,
mold removal
Epoxy coating
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Coastal Metal Roof agrace Roofing 4 09-12-2008 09:46 PM
Metal roof??? Tdoggy187 Roofing 51 03-04-2008 04:35 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
