How Remove Garage Door Opener - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-05-2013, 05:56 AM   #1
How remove garage door opener
I got a old Sears garage door opener that is binding and I am thinking about
just removing it and going manual. I got a second bay that is manual with
exact setup except no automatic opener. Can I convert the automatic bay
to manual? It is the Sears Craftsman model 139.53310. Right now it is off line and stops 4 feet up. But really don't want a new one as seldom use it.
sandyscamper is offline   Reply With Quote
Old 03-05-2013, 06:24 AM   #2
DIY staff
Rewards Points: 7,174
Usually you can leave the old opener in place and simply remove the lift bracket from the door---often there is a lynch pin that can be removed to remove the lift arm from the bracket.
drtbk4ever (03-05-2013)
Old 03-05-2013, 10:58 AM   #3
Rewards Points: 14,306
Or just pull on the reliece rope to disconnect the door from the opener.
Old 03-05-2013, 06:26 PM   #4
Roofmaster
Rewards Points: 2,210
Most are spring loaded and will snap back in to the slide bracket when you raise the door, Joe. He'd be better off removing the bracket, like Mike said.
Old 03-05-2013, 08:40 PM   #5
firehawkmph's Avatar
Rewards Points: 1,922
Remove the lift arm like previously stated, then pull the release rope and slide the carriage the lift arm was attached to back to the opener head end of the track. Keeps it out of the way of the door. If the track is mounted just above the door, within a few inches, the door will hit the carriage if its down at the door end of the track.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 01:08 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
