Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-13-2008, 09:38 PM   #1
How to remove drip edge to get to replace fascia board
I have a metal drip edge covering my fascia board. I need to get to the fascia board but my drip edge is covering it. How would I take the drip edge off so I could replace the fascia board? It appears that there are nails under the shingles holding the drip edge.
mr-hobo is offline   Reply With Quote
Old 07-14-2008, 07:16 AM   #2
747
registered
747's Avatar
You have to carefully pry those shingles up with a thin flat tool. Then remove drip edge and replace with new drip edge. Then reseal down all the shingles with roofer caulk Or the black caulk roofers use. you could try to reinstall that drip edge but i wouldn't recomend it because your going to bend it prying it off. NOw when taken it off. Take a flat bar and pry off at the nails. Meaning get under the drip edge or apron at the nail and pry up. Be careful with the shingles.
747 is offline   Reply With Quote
Old 07-14-2008, 10:28 PM   #3
Super Moderator
747 is absolutely correct, with an emphasis on removing it carefully.
Don't go cracking the shingles above it.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
What type of wood is used to replace soffit and fascia board? creamaster Carpentry 6 07-16-2008 02:20 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
fascia and drip edge glassman General Discussion 3 10-02-2006 07:39 PM
